I'm started when do we go camping
Washington, Oregon, Idaho & Alaska
Postby dahoon » Wed Jan 31, 2007 1:42 am
I posted some pics and will have some more updated pictures in a couple of days.
The frame is pretty much done and the wiring is going on. The first of Feb. I will be picking up the wood for the cabin.
I'm shooting for the first of May to complete it.
Mike
dahoon
Images: 76
Postby bledsoe3 » Wed Jan 31, 2007 1:53 am
If you're done by the first of May, then I guess you should go camping May 3-6 at the Dam Gathering. http://www.teardrops.net/14thDG.html Should be a good one, and lots of other teardrops too.
bledsoe3
Images: 112
Postby dahoon » Wed Jan 31, 2007 1:58 am
Cool a goal, the challenge is on.
I'll mark it on the calender and get busy.
dahoon
Images: 76
Postby bledsoe3 » Wed Jan 31, 2007 2:11 am
Nothing like a deadline to motivate. Good luck and keep us updated.
bledsoe3
Images: 112
Postby jdarkoregon » Thu Feb 01, 2007 3:18 am
dahoon,
your build reminds me of mine, what ya doing with the extra axle? getting ready for you second build already?
May is a good deadline, don't forget, GO LIGHT, if you learned anything from that trailer you demolished, it was build light and lasted a very long time, thicker wood wouldn't have helped it last any longer
I hope to meet you someday
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby bledsoe3 » Thu Feb 01, 2007 3:31 am
jdarkoregon wrote:May is a good deadline,
John
So you are going to make it to the Dam Gathering...
bledsoe3
Images: 112
Postby dahoon » Fri Feb 02, 2007 12:11 am
Weight is (good or bad) not an issuse on this TD. I'm using the old frame which is 4" C-channel. The bed is 9'-6" X 5'. So it will be a little heavy. If there is a next build I will definitely do it differently with box tubing. The money savings is substanial and tearing down the trailer was fun. But, I still had to disassemble it completely to resize it and take care of rust. I haven't found anything I would change yet, but then I have only just begun. (give me a chance, lol)
It should however, pull okay with a 4-cylinder, but beings I'm an old Chevy guy that just won't due.
Next winters project is my '76 Chev short-box stepside pick-up. It has a 6-cylinder and 4-speed. It will be converted to a 454 w/TH400. Yhe paint looks like it was done with a Wagner power sprayer, and has the typical rust spots. So, it will get new fenders and floor boards. The bed needs new wood and I'm leaning towards a burnt red with a woodgrain insert for a paint combo. Ah but I degress;
The other axle from the trailer replaced an axle under a utility traler I no longer needed. So I sold it to raise the seed money for the TD. Both of the axles had to be shortened.
I'll need to get thru the first build before the accountant will authorize a second build, she is warming up to this one. But, if I hit a homerun with this one I may building more.
As for the Dam Gathering, I'm thinking it's a little far to go this year especially on the maden voyage. Haven't checked mapquest, but it looks close to 900+ miles each way. I'm thinking the pennisula or maybe Ocean Shores. Maybe, even Winthrop. The North Cascades will be spectacular that time of year.
dahoon
Images: 76
Postby dahoon » Fri Feb 09, 2007 1:29 am
Trailer up date and pictures are posted.
Battery Bos is done (except for the lid)
Front marker lights are intalled.
I'll pick up the lumber the first of next week.
Goals:
Floor in February
Walls in March / Start the Cabinets
Roof in April / Finish the Cabinets
Camp in May
Collapse in June
dahoon
Images: 76
Postby bledsoe3 » Fri Feb 09, 2007 1:39 am
Dahoon, looks like you got a good start. I like how the box sets between the tongue rails.
Are you sure your frame is strong enough? :lol:
bledsoe3
Images: 112
Postby dahoon » Fri Feb 09, 2007 1:49 am
I guess I should show the brackets under the box welded to the tongue. The box is sitting on two angle iron across the front and back for support which drops it down an additional 3 inches.
dahoon
Images: 76
Postby bledsoe3 » Fri Feb 09, 2007 2:11 am
They show a little in the front view picture.
bledsoe3
Images: 112
Return to North West
