Here is an interesting fact.
Most any packaged food that involves boiling (like boxed macaroni-and-cheese dinners) will have "high altitude" cooking instructions. I have here a box of Hamburger Helper that says:
High Altitude (3500-6500 ft): Decrease hot water to 3-3/4 cups. Increase simmer time to 17 minutes.
The reason foods have these instructions is because the boiling point of water changes with altitude. As you go higher, the boiling temperature decreases.
At sea level, the boiling point of water is 212 degrees F (100 degrees C). As a general rule, the temperature decreases by 1 degree F for every 540 feet of altitude (0.56 degrees C for every 165 meters). On top of Pike's Peak, at 14,000 feet, the boiling point of water is 187 degrees F (86 degrees C). So pasta or potatoes cooked at sea level are seeing 25 degrees more heat than pasta or potatoes cooked on Pike's Peak. The lower heat means a longer cooking time is needed.
