by Syekick » Mon Apr 11, 2005 12:49 pm
As a third generation Lodge cast iron cookware user, I highly recommend that brand. Why all this talk about seasoning or preseasoning? The seasoning is nothing more than baked on grease or oil. There are two reasons for doing this.
1. It prevents rust!
2. It makes the item non-stick!
It's the original non-stick cookware.
Hard core cast iron users say to never wash cast iron. I'm refering to my grandmother and mother who taught me the same. Their reasoning is that is removes the seasoning and flavors the grease with soap. They would simply wipe the pan clean. The secret is to always preheat the pan/dutch oven before adding any ingrediants. That way the heat kills any possible germs. The Lodge Cast iron company does not recommend the use of soap in cleaning. They recommend use of a stiff brush and hot water. No soap.
Over coals or a campfire, the legs raise the dutch oven slightly to allow air access to the fire. A flat bottomed pan would put out the fire / coals under it.
<b>Fudd's First Law of Opposition: </b>
If you push something hard enough, it will fall over.
