Turkey Brine? need help!
Postby campmaster-k » Wed Nov 23, 2011 9:24 pm
Need help, Turkey Brine? I want to brine the turkey and dont know how muck salt to use.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby bonnie » Wed Nov 23, 2011 9:42 pm
http://allrecipes.com/Recipe/turkey-brine/detail.aspx
This one is very close to what I have done in the past. Before I cook the bird, I generally place one or two fresh onions in the body cavity. Then I liberally coat the outside with olive oil. Bake until 160 internal temp, or the legs are loose in the socket.
Good stuff.
Remember, the turtle won. :)
bonnie
Images: 107
Postby CliffinGA » Wed Nov 23, 2011 9:55 pm
Kirk this is from Foord Network and is Alton Browns recipe and video. My best friend did it last year and it was excellent!
http://www.foodnetwork.com/recipes/alton-brown/good-eats-roast-turkey-recipe/index.html
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby campmaster-k » Wed Nov 23, 2011 10:05 pm
Thanks all you saved me.
-Kirk
Build thread -
campmaster-k
Postby campmaster-k » Fri Nov 25, 2011 2:59 pm
What I ended up with is 1 cup of salt and 1 cup of sugar. 20 lb bird in five gal bucket. The liquid was about 2 gal. worked great.
-Kirk
Build thread -
campmaster-k
Postby gregp136 » Sat Nov 26, 2011 10:10 am
Life is good!
Greg(and Laurie)
gregp136
Images: 100
Postby AddOptions » Wed Nov 30, 2011 12:16 am
This is a great trick for camping, too. I've put pork chops or chicken into a brine with ice and then packed it in a small lunchbox sized cooler. It makes the chops or chicken tasty and moist when putting on the grill or cooking in the dutch oven. And the brine, since it's salt water, keeps things cooler longer.
A quick cheat is to make homemade ice cream while camping, then dumping the meat into the salt water the ice cream was made in. Add some sugar and your favorite spices and you have a simple easy brine. If the meat was frozen when you threw it in the brine, it will be ready for lunch the next day. And since salt keeps things preserved, adding a little ice and your meat won't spoil. I ended up doing this on a trip when we lost all of our refrigeration. Worked like a charm.
AddOptions
Re: Turkey Brine? need help!
Postby GerryS » Thu Nov 15, 2012 5:32 am
Check you tube. Alton Brown of good eats fame has made it there, and his videos are really goof proof, except his cheesecake :). That needs a little more time and heat than he claims :)
GerryS
Users browsing this forum: Google [Bot] and 1 guest
