by mournlight » Wed Jul 05, 2017 9:14 pm
Hey, Mark and Rose:
I have one I build last year which didn't get finished because I only had 3 weeks to work on it. It is a 5x10 enclosed cargo, studs every 12 instead of every 24. Solar on roof. foam sprayed into walls. Fold down bed. Rudimentary kitchen in front. Definitely needs some finishing. All solar working - you have a good battery, good meter, good panel, and components in place to charge phones, watch tv, etc. The underside was coated with protectant seal. More wires were run. More switches/options exist. Unit is insulated very well. (open a window when you use the fan - it is airtight! Lots of underbed storage. Roof rack.
I once had a Go Little Guy pod. It came apart. I kept the doors and cabiniets from that if anyone can use them.
