I have an all new 4' x 9' rolling chassis for sale. The main frame is made out of 2''x2'' 3/16'' wall sq tubing. The cross members are made out of 2''x2'' 3/16'' angle. The coupler is a Bulldog forged steel coupler, 2'' ball. It has a Fulton 2,000lb a-frame jack. It has 2 HD safety chains, rated at 5,400 lbs each. The axle is a 2'' drop 3.500lb cambered 2''x2'' 1/4'' wall sq tube axle, 5 on 4 1/2'' wheel pattern. It comes with 3 new Dexter 13'' rims with 3 new 185/80R13''s tires on them. The leaf springs are rated for 1,500lb a pair on the axle. The tounge is 47'' from the ball center to the front cross member. The frame is 108'' from the front cross member to the back. The axle is 38'' forward of the rear cross member. The main frame is 50'' wide. The top of the frame is 17'' high. The ball is 16'' high. There are pic's of it posted in my personal gallery. The trailer is in Bakersfield Ca. It is a rolling chassis, it can be towed away to its new home. $600. 1-661-398-9277......
Note, The pic's show it as a non-drop axle. The trailer seemed alittle high to me, so i replaced the axle with a 2'' drop axle. It is all new as well. I also added two more fishplates on the outside of the tounge to main frame rails like the ones on the inside of the frame rails and boxed in the back of the coupler as well.
