Kussmaul Auto Charge 1000
This is an onboard automatic, 15 amp battery charger that keeps batteries charged and this unit also has a 4 amp output circuit for charging hand lights, running interior lights or mobile radios ect. this unit is basically new, just been tested and played with verifying it worked correctly. I was going to use this in my off road build but plans changed.
These units are very expensive and mostly used on fire trucks and ambulance type vehicles, These units have built in controllers that will not overcharge your batteries. Kussmaul makes the best when it comes to chargers. this unit would work awesome for a teardrop or any camper build. , can do paypal and ship straight to you or cash pick up, either way is good.
just wanted to add, this unit is very simple to hook up, 2 wires coming out to your battery, a hot wire and the ground directly to your battery, and you have an extra hook up for constant power, 4 amp hook up on the unit to power all your 12v goodies, LED lights, mobile radios, ect ect.
UNIT SOLD!! NLA!!
