Everything included except pots/pans and cookware. I really hate to do it but it is for the best. If interested let me know and I can give you all the specs. Price is $3500 delivery included within a couple hundred miles of the Dallas/Ft. Worth Metroplex. Outside of that we can negotiate.
It is titled and registered as a travel trailer in Texas. Registration is current and there are no liens on it. The tires only have a couple off thousand miles on them. It is always stored in the garage when not being used. It weights about 1700 lbs when loaded for a 2 week camping trip.
features:
- 36v 190w solar panel w/ Blue Sky MPPT charge controller.
Progressive Dynamics 40 amp power converter for shore power.
Optima Blue Top Marine battery
set up for vehicle/shore/solar power charging
2 - 120v power outlets on separate breakers. One inside for AC or other accessories. One in galley for cooking or etc. Only usable with shore power or genset. No inverter.
New 7000 series Fantastic Vent fan with remote.
12v LED interior lighting
2 - 5v USB charging ports
5000 BTU Air Conditioner (shore power only)
Fully insulated sleeping area
Independent suspension
5x4.5" hubs w/electric trailer brakes (currently has spacer/adapter to the new Cherokee bolt pattern) Easily modified by replacing the hubs to match your bolt pattern.
Aluminium Wheels with automotive tires
Multi-axis hitch rated at 12k lbs. (did I mention this was overbuilt)
approximately 18" of clearance between frame and ground.
Full metal frame under body.
sleeps 2.
entry doors on both sides.
please email me: storm@hudsonhawk.net.
