2017 4'x8' 375 lbs Foamie Trailer $2999.95
Postby ghcoe » Fri Feb 02, 2018 3:10 pm
Contact: [email protected]
Home made 2017 Mini Light Sleeper Trailer.
This trailer weighs 375lbs.
Does your vehicle have limited tow capacity, 1000lbs or less? Then this trailer might be the answer to your camping/traveling wants without purchasing a bigger vehicle and/or sacrificing fuel efficiency.
This trailer is a new build concept blending new materials with old school technology. Starting with modern 2" XPS foam and finishing with a painted canvas covering that goes back to deck work of old wooden boats. Then the addition of modern manufactured doors and windows makes for a great light weight trailer ready to take on those adventures of the future.
Benefits of this build concept are:
-It is light weight. This trailer weighs less than half of similar built trailers.
-Built in insulation. 2" XPS insulative foam is built into the walls, a added cost on other trailer builds.
-Warm walls. Ever roll into a wood wall?
-Less worry about wood rot. Since the only part of this build that is wood is in the floor there is less worry about water damage.
-Seamless construction keeps water and dust intrusion to a minimum.
Other info:
-This trailer will fit into a garage.
-Has a tongue jack for easier moving.
-1/2" foam floor covering for even more warmth.
-2" reciver.
-4 pin connector.
This trailer is built on a manufactured utility trailer and will be supplied with a "Certificate Of Origin" for registration in States that require titling. For Idaho residents no title is needed, just plates for trailers under 1000lbs.. A "Bill of Sale"will be issued for registration/title purposes.
$2999.95 Thanks for looking. George.
inside
2
2
1
George.
ghcoe
Re: 2017 4'x8' 375 lbs Foamie Trailer $3299.00
Postby ghcoe » Sun Mar 18, 2018 9:00 am
Weather is getting warm, camping season is around the corner. This trailer still up for sale. Thanks for looking George.
George.
ghcoe
Re: 2017 4'x8' 375 lbs Foamie Trailer $2999.95
Postby ghcoe » Sun Apr 01, 2018 5:38 pm
Updated price... Thanks for looking, George.
George.
ghcoe
Return to For Sale/Wanted
