2018 Inka Hustler-X Teardrop Camper
Camp and social distance in luxury and style with this LOADED teardrop camper. Amenities include gull-wing entry doors, hot water (complete with outdoor shower attachment), air conditioning, queen-sized bed with 9.5-inch-thick memory foam mattress, integrated Weber gas grill, axle-less suspension, 18-gallon fresh water capacity, two 55AH AGM batteries, and more! Low miles. Hate to see it go but hoping to find a good home for a great camper. Please PM if interested. Located in Raleigh, North Carolina. $15,700.00.
General Features:
• Box section, fixture-welded steel frame with powder-coat finish and a CAD designed, single-piece, sustainable-wood & epoxy/fiberglass composite fabricated body
• Durable, easy-to-maintain textured urethane/epoxy hybrid exterior finish
• Timbren Axle-Less 1-Tonne (2200lb) suspension
• 10″ electric brakes (requires brake controller in tow vehicle or remote brake controller)
• 18-inch Subaru wheels
• Full-size spare tire (also doubles as spare for tow vehicle if you happen tow with a compatible Subaru Outback)
• Heavy, 11-gage diamond-plate “Jeep-style” fabricated fenders
• 6.1 cubic foot lockable front storage box
• 2” ball-type coupler
• Removable leveling jack on trailer tongue & dual stabilizing jacks at the rear
• LED running lights, LED outside flood lights and all LED interior lighting
• 2” receiver at rear for bike rack or carrier (300 lb weight limit, not for towing)
• Dual 1¼” receivers for grill or accessory mounting (not for cargo carrying)
• Front accessory mounting receiver
• Reverse lights and reverse floodlight interconnect
• Dual Manchester 5# 1.2-gallon propane tanks - off-road, bracket-mounted type
Interior Cabin:
• Insulated, dual gull-wing entry doors with tinted awning windows & bug screens
• Air conditioning with heat, ducted with wall thermostat, built in to the cabinetry, 120V AC
• 14" variable-speed reversible MaxxAir vent fan with rain sensor and remote control
• OceanAir window shades
• Automotive-type locking door handles, keyed alike
• Queen-size, high-quality IKEA (Myrbacka model) 9.5-inch-thick memory foam mattress with washable cover
• Overhead LED lighting & dual LED reading lamps
• Seven large cabinets with flush pull-handle latches & multiple storage shelf areas
• Dual USB charger ports, 12V outlet and 120V-AC outlet (when AC is available)
• Smoke and CO detectors
• Satin polyurethane finish (natural) throughout interior & galley
Galley:
• Pressurized water system – 18-gallon fresh water, 7 gallon grey-water
• Over-sized stainless sink with gooseneck faucet
• Propex LP hot water system with detachable shower and hot water at the sink
• Large work area with six cabinets
• Stainless steel counter surface & backsplash
• Over-sized galley door provides shade and rain shelter
• Two burner LP gas cook-top
• Weber Q1000 gas grill with folding hitch mount and low-pressure hose assembly
• Space for microwave oven or compact convection oven (generator or shore-power req’d)
• Sliding cooler/fridge tray (will accommodate ARB 37-quart refrigerator/freezer or Yeti 45-quart cooler, not included)
• Dual overhead LED work lights & LED multi-color, dimmable lights with remote control
• Dual USB charging ports, 12V DC outlet & battery voltage meter, 120V outlet (120V avail. with generator, shore power or inverter)
Electrical:
• 2000W Krieger Modified Sine Wave inverter system with automatic 120V switchover
• Dual 55AH AGM type batteries - bank capacity of 110AH with 35 amp automatic DC power converter/charger
• 120V-AC 20A shore connection
• 120V dual outlets in cabin and galley
• DC circuit breaker/switch panel located in cabin area
• 7-pole RV-style trailer electrical connector
