mikerueve wrote:I'm with Grant on this one. This looks like something that would make a great starting point for a novice.
I am one of those people who have very limited wood-working skills and felt so intimidated by the building and
assembly process that we are having one built as we speak. I think that if there had been a "kit" like this available, that I might have seriously considered taking a chance.
I love the idea of having one that I built myself, but have to realize my limitations. That and the fact that we would like to start camping again sometime this decade. I will be watching this thread with MUCH interest.
wagondude wrote:I'm not convinced that insulating or foamie construction would require a different offset to the flange. If you skinned with 1/8 or 1/4" ply, then just bond your chosen foam to the inside. You could do the same with two layers of foam easily enough. Then skin over with either canvas or glass. This is a great idea.
wagondude wrote:Now if a different offset were used, you could just edge groove the foam and insert the flange. But I don't think it would be necessary.
Martiangod wrote:The biggest problem less skilled have is achieving a clean finish on the exterior on complex parts. Although it is not really that complex. I think that would sell your package.
Martiangod wrote:As for a hatch, I think you would need to make 7 pieces to make it work. A top rail that Tee interlocks with your top rails and the hatch side radii and a bottom. These would form a frame and need to incorporate a drip channel to run off water, the inside lip could incorportate a bulb type seal like used on car trunks.
That they can source from any auto supply or ebay
Martiangod wrote:and for the hatch a top and bottom panel then a center section as Grant suggests, this would pack easier then a one piece hatch.
danlott wrote:Are the radius of the 12 and 36 inch corners measured on the outside our inside off the corner pieces?
Dan
