GeorgeT wrote:I like lots o' drills too.
I've determined the optimum number of cordless drills to have on a teardrop build is 3.
1) For the root diameter/countersink bit
2) For the clearance hole bit
3) To actually drive the screw
1 & 2 are a little wimpier... 3 is a heavy duty Porter Cable with 360 in/lbs of torque.
Also I don't have to lift weights on the days that I use that one, so it's a big time saver!!!
