OK ... all you wiring gurus out there. Last night I finally got to add the trailer wiring kit to my 91 Mazda truck. Being an import it has the independent turn signal circuit ... so I ran over to the auto parts store and pickup a Hoppy Converter # 48845.
Got everything wired up according to the simple wiring diagram from the trailer wiring kit and the fool proof makerings on the Hoppy converter. Well ... almost fool proof! Every thing works except the brake lights!! The last thing I did before knocking off for the night was to open up the brake light connector to make sure I got the right wire and yep ... there was power when the brkes were applied. But NO brake lights. The same circuit is used for the turn signals and they work ... so I'm assuming I got a bad connector kit ... but before I crawl under the truck again I thought I'd check with all the experts here.
Helllllllp ... please !!!! Wild Mike
