Cheapest way to insulate?
Re: Cheapest way to insulate?
Postby DriverOne » Mon Jan 21, 2013 10:45 am
eddie6775 wrote:I e-mailed this company today with an inquiry. Interesting... :thinking:
http://www.greeninsulationgroup.com/terms.php
That is now saved to my favorites, thank you!
Image There's a fine line between breathtaking ingenuity and "That's the stupidest thing I've ever seen!" Image
DriverOne
Postby pohukai » Mon Jan 21, 2013 1:30 pm
My insulation was free. A company I do work for had received marble table tops that were packaged in Styrofoam blocks 3"x 3'x3'. I got about 4 or 5 blocks. I cut them up and placed them in the roof. I used their old convention booth which was a kind of corrugated plastic board covered with a black cloth for the interior walls.
I haven't camped in it yet and don't plan on using it in temps below 30 degrees but besides the insulation, it will cut down on campground noise and rain noise. We'll see.
pohukai
Images: 9
Postby nevadatear » Mon Jan 21, 2013 1:37 pm
If you live near fernley, nv., Rmax has a manufacturing plant there. You can get end run pieces, slight defects for cheap. My husband did his machine shop addition for cheap. I'm sure other plants do the same. http://www.rmax.com/manufacturing-plants.asp
Owner,Desert Metal Products. Custom machine shop. Inventory of thousands of bearings and seals, from the common to the archaic.
nevadatear
Images: 145
Users browsing this forum: bc toys and 1 guest
