towing Compass Rose to California last summer was some what nervous making because our 2001 3L H6 Subaru was, well 11 years old. This year Nancy said it is time to replace it and like I'm going to argue? This was also driven (pun intended) by the death of its predecessor which was owned by my son (we gave it to him). It had reached 300,000 miles and had not been taken care of all that well.
I wanted another Subaru and a 3.6R which uses regular gas (the 3L used premium). The search with in a 300 mile radius for a lightly used that was not black or dark gray found one in Dayton that was a 2012 white and with white interior with 35,000 miles. I wanted a class 3 trailer hitch (more things will fit) and ordered one from E trailer along with the wiring harnesses. I have to say I ordered last Monday and had the hitch and harnesses by Thursday. I had the Curt hitch and wiring installed today (I did not want to risk the wiring) and the weight and difficulty of installing the hitch...
There are in my not so humble opinion three was of installing a hitch, The Uhaul quick and dirty slap it together tap off the existing lights using scotch lock... The Camping World put it together run the wires under the car ok it works sor of most of the item... and the BEST install I have ever seen.
The hitch had to be shoe horned in about two hours to install, the wring three lines from the battery one for the brake controller one for power to the plug and the third a 30A line to the back of the car for the refrigerator were routed through the fire wall and inside to the back where the brake and trailer power lines exit through a rubber plug to the seven prong plug.
Now I have to find the correct draw bar offset/height and a SS 2" ball.
