S. Heisley wrote:Doesn't the 6' high, similar to a T@B, have the galley inside?
Yes, unless you are looking at the Clamshell T@B...
danlott wrote:Here is a design that I came up with that is designed to fit on a 5x8 Northern trailer frame. It is fully self contained and has a queen size bed. The fender flares are premade flares from a cj jeep, so easy to find and inexpensive. The camper could be built without the more costly bathroom and kitchen amenities. As you had money and time you could install them.
I know it is not exactly what the poll is suggesting, but I think there would be alot of interest in it.
Dan
KCStudly wrote:I don't see the point of doing a traditional TD; those are already so well documented here; unless the goal is to provide step-by-step instructions for those that need a little confidence boost to make "the leap".
aggie79 wrote:Mike,
I like an outdoor galley. We love cooking a big breakfast while camping. Bacon and sausage grease/smell is not something I want inside a camper.
Take care,
as usual, I talk/write too much based on very little experience, and most probably I am "outside the box" again on my reasoning, but that's my view.I also see no need for a 5' high, at the present time, if I was to use it for single person camping, occasionally. That's what mine was built for. But, I also see a need for a taller, roomier trailer (of my manufacturing, not my wife's 20 footer), if a)we were to both camp in it together, b)either of us were to use it where we couldn't set up the "peripherals" - (canopy, porta-potty with cover tent, external cooking and cooler stands) due to time, weather, or space constraints, or c)becoming too physically inflexible to enter/exit/move around in the little 4x8 cabin. My next trailer (hopefully not too long till I can!) will be built to meet these three "new" refinements. I built the present trailer to the max height that I could fit into my garage/shop: made on a spring-suspension frame, 12 foot long, which is 24" to the floor (after installing 14" wheels/tires), and after adding the superstructure >> the thickness of the floor(3/4")+wall height(48")+roof(3/4")= 24+3/4+48+3/4 = 73.5" total height, it will barely fit into my garage bay, partially due to the angle of the slope into it. Build #2 will have to be stored outside, so 5' high (or maybe more) will be the order of the day. Even if I had used a different suspension on #1, it still wouldn't have squeezed under the door very easily, so I don't regret going that direction then. But, on the next one, a longer-taller-wider design, any of the 5'+tall designs would fit the bill. For TnTTT purposes, a teardrop shape is a must, but again, I will probably go outside the box on my #2 build.
