1 lb propane bottle debate revisited
Re: 1 lb propane bottle debate revisited
Postby 48Rob » Sat Apr 06, 2013 11:13 am
Brian,
We built that trailer on a very tight budget.
The deicer/anti freeze bottles, with their tops cut off and screwed to the wall held the spare 1# bottles behind the slide out cooler.
Rob
Visit Rob's World Web Page!
48Rob
Postby Vedette » Sat Apr 06, 2013 11:17 am
Good Idea!
And now that I have gone back to the picture I can see that.
Light weight and inexpensive storage!! :thumbsup:
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby markhusbands » Sat Apr 06, 2013 2:11 pm
The economy issue is legitimate, but for 20 bucks I can get a fitting to refill the disposable canisters and obviate that drawback. And, if you ever run out while you're on the road, you just buy a couple more disposables, use them on the trip, and retire the oldest in your disposable fleet after the trip. That's my plan anyway.
I'm just trying to figure out what hardware store fittings I need to make a homemade version of the Coleman Gemini. Can't be that hard...
http://www.coleman.com/product/geminitr ... WBzaqLvvTo
133923
markhusbands
Images: 58
Postby Corwin C » Sun Apr 07, 2013 11:05 am
Personally, I use the 20# tanks because there's a manual positive shutoff valve (no leaks), the economy of refilling the tank rather then discarding the bottles ($$$), and my trailer serves as a "bug out" resource. In case of a bug out, with two 20# tanks on my TTT, I'm prepared for over a week of judicious use even running the furnace, without the furnace more than a month wouldn't be difficult to achieve. Another nice fact is that propane doesn't go bad over time, so it's always ready.
When I get a tear built, if there's not room for the 20# I'll most likely use a 10# or even a 5#. I have tried re-filling the 1# bottles (actually illegal to do) with poor success. The valves in a 1# bottle are just too cheaply built to be reliable and in many cases, the appliance valves that these bottles fit aren't much better so leaving the bottle attached doesn't necessarily help.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby GuitarPhotog » Sun Apr 07, 2013 2:32 pm
So would one of you folks who are successfully refilling 1lb bottles please weigh a 1 lb bottle before and after and post exactly how much propane you are putting in the 1 lb bottle. Please.
I was told that using modern (OPD equipped) tanks, that you can't actually transfer liquid from large tank to small, but my source has been wrong before.
Also where do you get the tool to open the vent side of the 1 lb cans? Just like when they fill your 20 lb tank at the propane service, the tank has to be vented to allow liquid to flow from the large to small tank.
Thanks,
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Treeview » Sun Apr 07, 2013 8:29 pm
There are several posts on how to refill one pounders here:
http://www.instructables.com/
This is the most informative article that I've found:
http://www.neon-john.net/RV/Propane/Propane_index.htm
Treeview
Images: 30
Postby GerryS » Mon Apr 08, 2013 4:36 pm
How do Overflow protection valves affect refilling?
GerryS
Postby Dale M. » Mon Apr 08, 2013 7:19 pm
IF you are talking about refilling a large tank.....There is a float and valve assembly inside tank that limits a 5 gallon (potential) capacity cylinder to maximum 4.7 gallons .... As the level of liquid propane reached maximum allowable level it lifts the float and closes inlet valve... Pretty much like the "float" valve in standard toilet tank....
IF you are refilling small cylinder from a "bulk" tank, to get liquid you have to invert bulk tank so liquid is available at tank outlet (inlet) with tank upside down (inverted) the OPD valve should not effect flow.... With tank right side up all you get is a equalization of pressure and vapor in two tanks, you get no liquid transfer... Where the volume in refilling tank comes to play is how much actual liquid is in tank that can boil off (vaporize) into vapor (gaseous state)....
Also OPD valve have a anti free flow valve in POL connector...If shout on connector (regulator or filler device) is not fully seated in tank valve body, there will not be any propane flow.....
Further reading...
http://www.propane101.com/opdcylindervalves.htm
Dale
Dale M.
Images: 18
Postby CARS » Tue Apr 09, 2013 10:20 am
A few years ago my dad volunteered to refill my 1lb cylinders. The issue I noticed is that my dad filled off his 1000 lb home tank and the gas smelled of that "rotten eggs" additive they add to let you know you have a leak or failure in your home. I've never noticed that before when I bought the factory filled cylinders or 20lb gas grill cylinders.
But then, maybe it was me. Ever since I started using my pellet grill and charcoal again on camping trips, I can't stand the taste of gas grilled meats.
Chris'
Autobody
Restoration
Service
CARS
Postby parnold » Tue Apr 09, 2013 3:47 pm
GuitarPhotog wrote:So would one of you folks who are successfully refilling 1lb bottles please weigh a 1 lb bottle before and after and post exactly how much propane you are putting in the 1 lb bottle. Please.
Thanks,
<Chas>
:beer:
I have filled numerous tanks, but only weigh them and leave them outside for a couple days to make sure they are not leaking before storing them. I weigh them to an accuracy of 1/10 of a gram. I do not vent them when filling, I fill just like I used to fill paintball gun co@ tanks. I put some gas in them (my filling 20lb tank is upside down so I get liquid not gas), then let some of the gas escape. Letting some gas escape chills the bottles and allows you to get more gas in them. The next time I have an empty, I'll weigh before and after.
parnold
Images: 302
Postby jjjonz » Tue Apr 09, 2013 8:59 pm
I have been refilling 1lb propane bottles for years.Here is a good simple video showing you how.I leave my bottles in the freezer a hour or so before refilling...,,
http://www.youtube.com/watch?v=9Q2Jhbbmnos
jjjonz
Postby Dale M. » Tue Apr 09, 2013 9:30 pm
CARS wrote:A few years ago my dad volunteered to refill my 1lb cylinders. The issue I noticed is that my dad filled off his 1000 lb home tank and the gas smelled of that "rotten eggs" additive they add to let you know you have a leak or failure in your home. I've never noticed that before when I bought the factory filled cylinders or 20lb gas grill cylinders.
The odor is from, a odorant called Ethyl Mercaptan..... And almost all domestic propane contain it .... From #1 bottles to large commercial bulk 10,000 gallon storage...
A while back there was a recall because a batch of #1 bottle got through the filling process that was NOT odorized....
Dale
Dale M.
Images: 18
Postby slowcowboy » Wed Apr 10, 2013 4:17 pm
slow refills both the barbaque bottles and the green coleman cans.
I have a adapter that I refill about 5 green coleman cans on it all the time from a barbaque bottle.
for the barbuque bottles I have a hose and a adapter to my large house tank. I live in the country and we own our own tank. its also used to power a splinkler motor.
our house tank wich is a large 300 gallon tank has two outlets. one for vapor to run a gas four clynder motor and one for like the normal liquid outlet to a house.
I can fill a normal barbaque bottle by hooking a hose to the valve on the barbaque bottle off the house tank and I normaly hook to the vapor line on my house tank. I fill it much like they do at the propane places only I have no pump to do so and
free flow it across.
lots of us ranchers do this all the time and I have doing this since I worked on a ranch job.
as for the city guys the adapters for filling a green coleman can can be found at all most any where and harbor freight stores are loaded with them.
just hook the barbaque bottle and tip the bottle upside down and open the valve for a good minute.
it aslo helps to have the green coleman can chilled first by setting it in a freezer for a half a hour.
this helps the propane flow bettor.
I normaly don't buy propane. if I do its to get a full tank of liquid on a barbaque bottle and thats to get the little green coleman cans fuller.
to fill a barbague one I normaly need 60 percent on my house tank.
and we have a propane truck come out much like the gas truck.
we just call whos the cheapest for propane. as we heat with it on the house.
slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby slowcowboy » Wed Apr 10, 2013 4:21 pm
I don't weigh a bottle to fill it and I recomind avoiding a propane company that fills by weighing. that is cheating you out of any gas that is left in the bottle when you fill up and stealing your gas. I highly advise to use a company with a meter and one that meters the gas out and fills by venting the tank.
the green coleman cans don't need weighed and don't need vented. just hold them in your hand to see if they feel heavy and full. compared to a empty one.
its pretty much kiss simple to refill a coleman can!
slow
slowcowboy
7000 Club
7000 Club
Images: 166
Postby GuitarPhotog » Sat Apr 13, 2013 11:25 am
OK, well I've got an empty 1# can now, and a friend has the adapter. Here we go with a test 8)
Thanks for the info, there's so much contradictory, and often wrong, info that it's hard to figure out sometimes. I'll pass this stuff on to the guy who told me it can't be done -- after I refill a 1# can :)
<Chas>
:beer:
GuitarPhotog
Images: 55
