Minimalist Tears
Minimalist Tears
Postby mikejohn37 » Mon Jul 03, 2017 5:31 am
I have designed a squarish camper for my own use. 8 x 4 x 4 roughly.
The front and side hatches are for access to the cabin and for extra ventilation in hot weather during the day. They will be fly-screened. The size of the side hatch is to suit a small air-conditioner and a removable shelf is for that purpose or it could be another pass through opening/table. Maybe it is a crazy idea. The air conditioner only comes camping in hot/cold seasons and is carried in the car.
The bed space is 78 inches long and 44 inches wide. Cosy. It could widen to 5ft but it is meant to be a low cost build and you get more out of plywood at 4ft wide.
The rear hatches are removable rather than lift up so I can park under low trees and they also will have legs and serve as camp tables.
It is a low cost build. No electrics - just camping lanterns etc. I will have an electrician put in one ac outlet if they will.
Questions? Comments?
Mike
Australia
mikejohn37
Re: Minimalist Tears
Postby mikejohn37 » Mon Jul 03, 2017 5:33 am
More pics.
mikejohn37
Postby friz » Mon Jul 03, 2017 8:46 am
My only addition would be a roof top vent with fan and a simple 12v system to power it.
Sent from my SM-G900V using Tapatalk
The "Sin Bin"
150133
friz
Postby VT800C » Mon Jul 03, 2017 10:11 am
nice design. I like the cables from the top to hold the shelf. and using the covers as tables? ingenious! I'd only be worried about how to seal the openings when closed up. you might find that adding the molding to hold the seals will increase the complexity of the build (I sure did!)
I say go for it! let us know how it comes out.
VT800C
Postby low277 » Mon Jul 03, 2017 11:23 am
:thumbsup: I like it!! Simple can be a good thing!!!!
NW Minnesota
low277
Images: 5
Postby mikejohn37 » Mon Jul 03, 2017 4:52 pm
Thanks for the comments. Now I have to build it. :-) I am going to fibreglass the outside of the walls and tape the outside joints. I need to credit only taking the aircon when needed idea to Coyote.
mikejohn37
Postby saywhatthat » Wed Jul 05, 2017 3:52 pm
For some reason I like the look ! . like what I'm trying to build.
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby tony.latham » Wed Jul 05, 2017 6:25 pm
My first tear didn't have a fan.. never again.
Postby mikejohn37 » Wed Jul 05, 2017 6:31 pm
Yes I have designed a diy hatch with a fan. Also, some air intakes as well. The hatch is the first thing I will make while I wait for other materials.
mikejohn37
Postby JuneBug » Thu Jul 06, 2017 8:50 pm
Suggestion. For the back, which may be your kitchen, or a place to store other gear. Gather up what will go there, measure and fit accordingly. For example, if you have a camp stove, make sure the depth of your shelf will accommodate it. If you have a specific type of water jug, make sure you can accommodate it.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Postby JuneBug » Thu Jul 06, 2017 8:51 pm
Suggestion. For the back, which may be your kitchen, or a place to store other gear. Gather up what will go there, measure and fit accordingly. For example, if you have a camp stove, make sure the depth of your shelf will accommodate it. If you have a specific type of water jug, make sure you can fit it in.
JuneBug
Postby ae6black » Fri Jul 07, 2017 11:31 am
My TD is minimal to say the least. When I built the thing, it was single purpose, to hunt out of in cold weather. Since I thought I wouldn't be using it much in the summer, I didn't bother putting a DC converter in, figuring that the Campgrounds I intended to use would have AC. So I just put a plain vent in my roof and had a window in the door and a window on the other side for fresh air. In the winter all you need is the vent and a window cracked to keep from suffocating in your sleep. In the Summer, not enough air moves to make camping in warm weather much fun. Then I discovered a 9 inch AC Fan from Wal Mart that I can tie to the roof vent that turns the TD into a mini wind tunnel. Makes using it in the Summer Heat with AC bearable.
Art
ae6black
Images: 19
Postby mikejohn37 » Sat Nov 18, 2017 6:54 pm
It is almost done. Filling holes, fibreglassing, sanding and painting to go and then fit all the hardware - locks, seals etc.
mikejohn37
Postby mikejohn37 » Sat Nov 18, 2017 6:55 pm
Sides up and floor in.
mikejohn37
Postby mikejohn37 » Sat Nov 18, 2017 6:56 pm
End view.
mikejohn37
