What did you do to your trailer today?
Postby Socal Tom » Sun Sep 17, 2017 9:30 pm
For my part, I installed a cheap PWM solar charge controller, and rewired a few things to that the controller could manage most of the load ( except the waeco fridge). I have a modified IKEA dioder LED system in my galley ( actually 2). I was surprised to see that it draws almost 1 amp when on white light, and about 4 when on blue or green.
Socal Tom
Images: 9
Re: What did you do to your trailer today?
Postby Aguyfromohio » Sun Sep 17, 2017 9:39 pm
I painted the underside of the plywood floor, and made a router template for the door latch.
Aguyfromohio
Images: 44
Postby daveesl77 » Mon Sep 18, 2017 6:43 am
Finished the cut and installed the aluminum framework I made to hold the two solar panels to the roof. Also made new panel supports that fold up inside the panel frame. All works well. Ready to go camping in a couple of weeks.
dave
daveesl77
Images: 273
Postby Socal Tom » Mon Sep 18, 2017 7:53 am
daveesl77 wrote:Finished the cut and installed the aluminum framework I made to hold the two solar panels to the roof. Also made new panel supports that fold up inside the panel frame. All works well. Ready to go camping in a couple of weeks.
dave
I'm curious to see that. Any pics?
Socal Tom
Images: 9
Postby Socal Tom » Mon Sep 18, 2017 8:46 am
dave
Socal Tom
Images: 9
Postby shootr » Mon Sep 18, 2017 9:45 pm
Put a new plastic cover on the roof vent. A storm blew the brittle original clean off, and one of the great vendors on here had an exact replacement for a super reasonable price, and shipped it super quick. Now just need a weekend to get out with it....
shootr
Postby Mr. Lahey » Tue Sep 19, 2017 6:08 am
Finished fitting both my doors.
Insulated both doors and attached interior birch door panels.
Doors will be ready for finish sanding, stain, and varnish today.
My teardrop camper build journal: viewtopic.php?f=50&t=64721
My tool box teardrop build journal: viewtopic.php?f=50&t=70817
Mr. Lahey
Postby Socal Tom » Sun Nov 05, 2017 1:44 pm
Made a few modifications to my loading. Expanded the tongue so I can carry a 20lb tank. Relocated my water to over the fenders.
I still need to trim the corner off the tongue board, but I promised not to get sawdust on the laundry, so I’ll do that next time I pull it out of the garage. Also need to paint a few things, but I want to make sure it works well before I invest the time into making it pretty. The P/S tank feeds my water pump, so it sits a little higher to allow for the fittings.
Socal Tom
Images: 9
Postby pchast » Sun Nov 05, 2017 9:28 pm
Cleaned and greased the wheel bearings.
pchast
Images: 96
Postby IndyTom » Mon Nov 06, 2017 3:03 pm
Completed the hatch for my underfloor storage and started fixing a major screw up.
Never trust a skinny cook
IndyTom
Images: 42
Postby Bigwoods » Mon Nov 06, 2017 8:11 pm
Since it was spose to be -3° last night I put some Irish Spring inside. I heard it keeps the mice out. Works cuz I have been doing that for 3 years and never had a mouse problem. Soon it will be time to sit by the fireplace and daydream about camping. :)
Greg in Northern Minnesota
Bigwoods
Images: 103
Postby ravenswood » Thu Nov 09, 2017 7:51 pm
I got mine bedlined todayImage
ravenswood
Postby slowcowboy » Fri Nov 10, 2017 3:49 am
walked by it in the shop the new one walked by the old one out side out front of the shop door tucked in for winter with the car tarp...ah. I have the flue this week. and on going ranch stuff. and good old slow time pace on the 2 build. slow :D
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby MtnDon » Fri Nov 10, 2017 1:50 pm
Wheels and tires. The wheels on our 38 year old 4x8, metal box utility trailer, were allowed to get very rusty. I've been having valve stem sealing problems because of the rusting. The UT does not get used a lot and the use is mostly around town. No long trips with it.
So, I bought 2 new white spoke trailer wheels and had them fitted with new made in USA Goodyear Endurance tires (ST205/75R15). Those new wheels and tires were placed on the CTC. The now almost 4 year old chinese tires and wheels from the CTC (same size, same wheel bolt pattern) were then installed on the UT.
And the tire shop was good enough to not charge me the used tire disposal fee, when I asked if they would do that.
MtnDon
Images: 24
Postby cajundood » Sat Nov 11, 2017 4:27 pm
I installed a window :D
cajundood
Users browsing this forum: gudmund and 2 guests
