tony.latham wrote:Good question.
Some builders attach the fenders to the walls. We mostly boondock so there is always a chance of catching a fender on a stump or other obstacle and banging a fender that's screwed to the sidewall might result in severe damage to the wall.
Your chassis screams off-road thus I wouldn't recommend you put the fenders on the walls. I would consider welding tubing under the chassis laterals to support your fenders. If you weren't overlapping your walls, you could butt the tubing. (Or you could slot the overlaps to fit?)
And that brings the discussion on how you are going to build. On my last two builds, I've done the cabin on a dolly and installed it on the chassis after it's nearly done. (But I don't overlap and that could make for a loading challenge.) It's a pain to work around fenders, wheels, and the tongue. Either way, I'd for sure fiberglass your walls before you install them on the floor.
eagle24 wrote:Got my frame all done except the fenders. I plan to let the outer plywood lap over to hide the frame. The outside will be covered with epoxy/fiberglass cloth and painted. I'm not sure how I should do the fenders or when I should do them. What is the best way to do them? I want a sturdy fender that can be stepped on.
working on it wrote: from another thread:
- I have no experience with attaching fenders directly to either foam or wood trailer walls, but many years of experience with using steel fenders attached to trailer frames, using inner shields of steel, or hard plastic, on mostly open trailers. I've seen, and experienced damaged fenders, from encountering large road debris... or in one case where a tire blew-out, and the shredded tire had enough force to damage my thick steel fender (I was driving at 75+ mph), but my race car on the trailer was untouched, saved by the inner fender shield.
- If you need to attach your teardrop or TTT fender directly to the wall itself, and not isolated from it, by frame or suspension mounts, then use heavy-duty hardware, and use an inner shield (backing plate) in any case. Using 1/8" spacers might allows water to drain from the fender-wall interface, but if a backing plate is used, it will make the spacer unneeded. On my squareback trailer, I used both a frame-mount, a backing plate, and also left a 1" between cabin wall and fender assembly; no water or dirt ever touches the wall, protected by the isolated fender (I can easily clean my wall behind the fender, also, with a thin sponge).
- My trailer is an odd width, 50", and my floor is 48" wide (my walls sit on top of the floor, giving me 46.5" inside cabin width), so that left me with the 1" gap between frame edge and walls, making attachment directly to the sidewalls infeasible. And, with my first axle not having brake backing plates, the free-floating fender assembly that I would've used (I've admired them on many street-rods, and wanted to build one) was impossible also. So, frame-mounting was the best choice, in my case. Since my design intent was for a heavy-duty, semi-offroad trailer, I bought heavy steel fenders with optional backing plates, welded the plates on, and welded (not by me, but by a pro,,,I didn't weld when he was available!), and welded them onto the frame in five spots (not a continuous weld, to avoid warpage), with stiffening bars (1" steel angle) on front and rear fender edges (also welded to the frame). Very strong, very protective!
- alternative fender-mounting ideas; I recommend using an inner shield on all fenders
NorthEGPhoto wrote:Hmm.. if standing on it is what you want, I expect the best course of action would be to weld a frame out of 1" square tubes in a polygonal shape Think something like /─\ then weld plates on the frame. My dad did something like that with his landscaping trailer when the original round fenders rusted off. We stand on them all the time. since you won't have the advantage of a full steel box, you'll probably have to think of a way to reinforce them with bracing. maybe brace them from below, but that will reduce your clearance a bit.
eagle24 wrote:I really have some things to figure out here. Several issues....
if I center the fender on the tire, it won't be against the trailer side. If I put it against the trailer side it won"t be centered on the tire and it won't cover the entire tire width. This is a 10" wide fender.
