Mr Heater vs Propex HS2000 heater
Postby Cosmo » Tue Oct 09, 2018 5:45 am
Mr Heater Buddy space heater $70 (4000 BTUs 2 speeds ON and OFF). Ventilation required.
Compared with the $900 Propex HS 2000 (6500 BTUs) Forced Hot Air heater with thermostat and no fumes and no propane combustion water vapor.No ventilation required.
Sorry no below freezing tests yet due to Mother Nature not providing cold weather yet! Will update as it gets colder.
https://youtu.be/V8OHRW98G5U
=Cosmo.
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Re: Mr Heater vs Propex HS2000 heater
Postby KennethW » Tue Oct 09, 2018 7:21 am
Nice comparison. One more thing about the buddy is the fire danger if it gets too close to flamables. I like the lower cost Chinese diesel parking heater(for those that want something a little lower in cost) They are fully vented small in size and cost less than $200.Image
Sent from my Moto G (4) using Tapatalk
KennethW
Images: 82
Postby John61CT » Tue Oct 09, 2018 1:09 pm
Link please?
John61CT
Postby Esteban » Wed Oct 10, 2018 1:09 am
Steve - SLO, CA
Esteban
Images: 15
Postby John61CT » Wed Oct 10, 2018 8:15 am
KennethW wrote: lower cost Chinese diesel parking heater(for those that want something a little lower in cost) They are fully vented small in size and cost less than $200.
Link to this item please?
John61CT
Postby KennethW » Wed Oct 10, 2018 8:26 am
Take you pick
https://www.ebay.com/sch/i.html?_from=R ... r&_sacat=0
This one seems to have all the right stuff included. Wow, You can turn it from your car on before you stop for the night.
https://www.ebay.com/itm/2KW-12V-Diesel ... :rk:4:pf:0
I burn Kerosene as it burns cleaner(less smelly) and will result in less maintenance.
KennethW
Images: 82
Postby tony.latham » Wed Oct 10, 2018 9:21 am
Take you pick
Kenneth:
How much does yours burn per hour and where do you buy kerosene these days?
Postby KTM_Guy » Wed Oct 10, 2018 10:35 am
I remember seeing 5 gallon containers at Manards. When I was living up north I knew of a few gas stations that had kerosene at a pump.
I like the Propex heater just not the price. I saw a review on the one of the diesel ones and the guy liked it but if it sat for more that a few months without being used it wouldn’t work. And would need to take it apart to clean. He said if it ran 20-30 minutes every months it was fine. I don’t see me doing that. KW have you had any problems?
Anyone know what the elevation max is on the Propex or diesel/kerosene?
Todd
KTM_Guy
Images: 193
Postby KennethW » Wed Oct 10, 2018 10:45 am
I have not had any problem with mine. That is why I burn kerosene. It just burns cleaner. I would say it may burn a cup on a very cold night. Not enough to even thing about. :thumbsup: If you can not find a pump most hardware stores have kerosene for space heaters(super clean).
KennethW
Images: 82
Postby John61CT » Wed Oct 10, 2018 10:50 am
Whole point if not propane is to use the vehicle fuel. Would not carry a third type.
Webasto and Espar have gasoline, dunno if those available as cheaply.
For Propex questions that Westy source above is canon.
John61CT
Postby tony.latham » Wed Oct 10, 2018 11:17 am
What are the higher elevations you've run it at?
Thanks,
Postby KennethW » Wed Oct 10, 2018 11:28 am
The highest I have been so far is around the Grand Canyon.
KennethW
Images: 82
Postby John61CT » Wed Oct 10, 2018 3:32 pm
Details specs and mods are available for altitude issues.
Some need manual adjustment, others an add-on to automate it.
John61CT
Postby KTM_Guy » Wed Oct 10, 2018 5:29 pm
KennethW wrote:The highest I have been so far is around the Grand Canyon.
South rim is 7,000’ north rim is 8,200’.
Todd
KTM_Guy
Images: 193
Postby KTM_Guy » Fri Oct 12, 2018 11:38 pm
I've been looking into heaters more and found some good info.
If you want to heat with gasoline it is possible but it come at a price. The only one I found is a Espar at 13,000 BTU's (probably to big for a teardrop) at about $1,600USD. If you are going to use it above 5-6,000' add another $300 for a high altitude kit.
Diesel heaters will build up carbon above 6-7,000'. The Espar has the high altitude kit that will give you up to 4'000m a little over 12,000'. The Webasto can be adjusted with flashing the board but they say max doing that is 7'000'. Espar and Webasto are in the $1000 range.
I haven't been able to find out if the cheap clone diesel heaters have any adjustments for altitude. My guess would be no.
I have two emails to Propex but haven't heard back yet. I have read that 10,000' it worked fine. Very cold temps (0 degrees) and altitude were problems.
Here is a good thread on heaters and altitude. It is a Westy forum and they really put a big value in the one fuel. I don't know if it applies to us with trailers as much. https://www.thesamba.com/vw/forum/viewtopic.php?t=608699&postdays=0&postorder=asc&start=0&sid=8f8184960e44fc15598f4cd78f5c1c28
There is a heater like the Propex coming to the US next year that looks nice Truma VarioHeat eco. But they look like they will be $1100 without installation kit.
Bottom line, if you want to stay toasty warm at 10,000' or above you are going to have to shell out some cash for it.
KTM_Guy
Images: 193
