Schrader valve on a white gas stove
Postby saywhatthat » Fri Jun 05, 2020 12:24 pm
As white gas burns better at higher altitude. I have a few 3 burner white gas stoves. But all that pumping. Is there any reason not to install a Schrader valve ? Just one pump from a hand pump .you be done .Also can use un lead fuel
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: Schrader valve on a white gas stove
Postby RalphCT » Fri Jun 05, 2020 3:44 pm
Care should be taken so as to not over pressurize the stove.
White gas burns cleaner but unleaded can be used in most stoves. But unleaded gas has a variety of additives that are best not combined with food by cooking with unleaded gas.
RalphCT
Postby saywhatthat » Fri Jun 05, 2020 3:57 pm
RalphCT wrote: to not over pressurize the stove
Thank you for the reply . That why the hand pump .Did a test on the tank at 8 lbs. it start to leak at where you pump at. Added air on the gas out put tube
saywhatthat
Images: 135
Postby GTS225 » Sat Jun 06, 2020 5:08 am
Saywhat; I might suggest you outfit your stove with a low pressure gauge first, to see what pressures are achieved with the factory hand pump, when the burners are operating as they should. This way, you'll have a baseline pressure, rather than guessing what pressure to stop at with a larger volume hand pump.
I applaud the idea for improvement, but really must insist you approach with caution. You are, after all, messing with a pressurized container of flammables, and there's already a source of ignition at hand if it ruptures.
Just my 2-pence.....Roger
GTS225
Postby tony.latham » Sat Jun 06, 2020 10:46 am
I grew up somewhat off-grid. One of my jobs was to fill the lanterns and stove each morning. I guess I was traumatized, so I'll stick to propane. :?
Snap the piezo and you're cooking with gas.
:applause:
But I'll still camp next to you green-stove fellas. :thumbsup:
Postby saywhatthat » Wed Oct 14, 2020 10:09 am
What has work great or us . 12 volt air compressor . open valve on long tube hit with 6- 10 psi .Some air will leak by. close valve .A bit of gas in burner to pre heat tube No dam pumping. No Schrader valve :thumbsup:
saywhatthat
Images: 135
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
