GTS225 wrote:I'd bet it's not safety glass, but tempered glass....
* I think you're correct...though the broken window stayed together for awhile, the slightest touch would break off segments. Not so on auto safety glass, which is two pieces laminated together with a plastic sheet in-between. If it had been laminated auto glass, I could've pulled it out as a larger piece, held together on the plastic.
* That said, it took us a couple of hours to remove the broken glass and adhesive, using a flat bladed screwdriver and a heat gun (to soften the silicone adhesive holding the widow to the frame), and to fabricate a temporary replacement until we get the tinted polycarbonate we'll use to permanently fix it. The next door neighbor (other side, not the livestock owner) had a couple of sheets of 3/16 polycarbonate leftover by the previous home-owner; we used one to fill the open window (trimmed to fit the exact opening, and Gorilla-taped in place).
- temporary polycarbonate window fix (left the paper on it).jpg (83.15 KiB) Viewed 1011 times
* With the window sealed, no birds, feral cats, dust, or rain can get in the trailer (hardly anything inside had gotten even slightly wet when the storm broke the window; must've been at the tail-end of the storm). I ordered a contour gauge and a 2'x4' sheet of tinted polycarbonate (1/8" thick, so the flexible rubber/vinyl? trim will fit back in place) from Amazon to fix the window permanently next week.
* The contour gauge will help us with the radius corners at the top, which we simulated using the new Gorilla-tape roll. Not perfect, but a quick fit. Our Dremel Sawmax had a plastic cutting blade that did a good job, so we're good there. I'll use my Wen rotary tool to dress the edges (I used a file this time, as we thought another storm was rolling in). What clear silicone (or polyurethane-based) adhesive should I use? I'm leaning towards OSI QUAD MAX clear (I used grey OSI QUAD on mt 4x8 trailer's windows...still great after 7 years).
