rjgimp wrote:I'm all in on some yet to be determined Rube Goldberg mounting system where some of it would deploy one direction and some the other. Maybe even spring loaded like a window shade. The coolness factor is certainly worth extra points in the overall scheme of things. It would also eliminate having to store it somewhere in between uses. However...
All things considered just tossing it over the top and staking guy lines tied to the corners, perhaps with 2 or 4 adjustable poles at advantageous points for water runoff, might be the best choice. Depending on your parking spot any given day, you might want more of it extended to the rear and to the passenger side and on a different day in a different location you may want the opposite.
dbhosttexas wrote:I am having trouble trying to imagine what you are trying to accomplish here. Are you trying to protect the pop up, or are you trying to provide a protected space under the canopy using the truck more or less as a wall?
If it's the latter, have you considered a 270 degree awning rig? That would give you cover across one side and the back at least, and there are lots of DIY designs out there for them...
Of course I may be totally off my rocker here. Been an odd week.
RJ Howell wrote:rjgimp wrote:I'm all in on some yet to be determined Rube Goldberg mounting system where some of it would deploy one direction and some the other. Maybe even spring loaded like a window shade. The coolness factor is certainly worth extra points in the overall scheme of things. It would also eliminate having to store it somewhere in between uses. However...
I'm falling into this idea as well. It struck me as having more options as you mentioned. I've tried a couple different deployments now and like the options. The fly packs small so stowing is not problem. The extending poles I would have to work out a system on the side of the cabin (outside).
QueticoBill wrote:Are you usually solo or two people.
