Milliard mattress base
Postby Simple_Abound » Mon Mar 25, 2024 8:33 pm
For starters I currently have a Milliard trifold mattress in my homemade camper. It's a 4 1/2 medium firm base with an 1 1/2 memory foam topper. It's currently flipped over so we're sleeping on the 4 1/2 memory foam base. It's almost perfect for my wife and I. Does anyone know what the density and firmness of the base is on a Milliard trifold? I was curious if it's comparable to an hd 36 foam. Thank you.
Simple_Abound
Images: 85
Re: Milliard mattress base
Postby cdnred » Wed Apr 03, 2024 8:54 am
A bit off topic but with the Milliard trifold mattress, can it be trimmed down for size using a knife to trim it down..? My teardrop camper bed is 48 in wide by 72 in long. Nearly all mattresses I've seen are 52 in wide x 76 in long as it is with Milliard mattresses..
cdnred
Postby Simple_Abound » Sun Apr 14, 2024 6:51 am
cdnred wrote:A bit off topic but with the Milliard trifold mattress, can it be trimmed down for size using a knife to trim it down..?
I did trim mine down. I'm not sure if there's fiberglass in the materials so be careful if you cut it. The cushions are in a cover that is sewed together.
Simple_Abound
Images: 85
Users browsing this forum: Onajourney and 8 guests
