Has anyone found or created a less expensive alternative tha
Postby mariehartley » Wed Apr 24, 2024 12:21 pm
I've noticed that when I'm at a campsite with WiFi, getting a signal inside our Faraday cage trailers is practically impossible. While I'm aware of high-quality devices like the Wee Boost, which can significantly improve WiFi reception for around $500, I'm on the lookout for a more budget-friendly solution. Has anyone found or created a less expensive alternative that's just as effective?
mariehartley
Re: Has anyone found or created a less expensive alternative
Postby Shadow Catcher » Wed May 15, 2024 8:47 am
Been there. Our tear has an all aluminum frame and is not quite a Farady cage but an external antenna is necessary much of the time. This does require a hotspot with antenna port or something like the WeBoost Drive Reach or Drive Sleek (older). With a bunch of adapters and with a omni or directional antenna mounted on a telescopic painter pole mast we have yet to be in a place where we can not get enough signal.
155982 155984 155985 163298
