If you used the 60/40 rule backwards to build your trailer, can you hook up the trailer at the rear instead of the front and tow it that way?
https://www.youtube.com/watch?v=1W5r7rrR_Mg
John61CT wrote:Hope you've got a steel plate under that batt, really should make up a full shield.
Real nasty when a rock punctures the bottom of your battery and leaves your '61 Beetle stranded out in the middle of the Simpson Desert.
Based on a true story
drhill wrote:dancam - I would think that there would be a self weigh scale somewhere in Nisku. Ask the next trucker you talk to.
Doesn't help you much, but in the Calgary area there is a self weigh just West of the Petrocanada at Hwy 1 and 22 and just South of the Petrocanada on Hwy 2 near Aldersyde. There are likely some self weighs in the Edmonton area too. The other option is the scale at the landfill, but it seems to me that is way East of Edmonton.
