Installing Aluminum Trim
Postby Capebuild » Fri Mar 18, 2022 4:14 pm
I'm trying to decide what would be the "best" sealant, or method of sealing, the aluminum trim to the aluminum sheeting (like the corners where the roof meets the siding). I can think of 3 materials but not sure if there are advantages of one over the other:
1) Butyl Tape
2) a sealant like Pro-Flex RV
3) VHB Tape
I'll be using aluminum moldings from Vintage Technologies and in addition to the sealant method will also use stainless screws to attach the moldings.
Asking for any thoughts and/or suggestions.......that would be helpful.
Thanks very much!
John
Capebuild
Images: 129
Re: Installing Aluminum Trim
Postby halfdome, Danny » Fri Mar 18, 2022 7:02 pm
John, I use OSI Quad clear.
It’s for aluminum and other uses, great stuff and cleans up with lacquer thinner.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby dmdc411 » Fri Mar 18, 2022 7:46 pm
I used OSI clear, and white. Put it between layers on roof joints, under the trim, and on every screw shank at install. Messy, used lots of tape, and alcohol for clean up! Not a leak after 9 or so years. Butyl tape attracks dirt, and in my opinion, it pushes out from expansion and contraction, allowing water in.
Sent from my SM-G970U using Tapatalk
dmdc411
Postby Graniterich » Fri Mar 18, 2022 9:39 pm
I swear by lexel!
Sent from my KFTRWI using Tapatalk
Graniterich
Postby noseoil » Sat Mar 19, 2022 8:34 am
Low tech here, butyl tape & no problems after a few years of use.
137905
noseoil
Images: 669
Postby randb » Sat Mar 19, 2022 4:21 pm
Absolutely agree, 6 years on still no leaks. Butyl tape is great. Easy to work with too.
Sent from my SM-N960F using Tapatalk
randb
Postby airdonut41 » Mon Mar 21, 2022 6:15 pm
One more quick comment: VHB tape isn't really a sealant. It's great stuff, but it won't serve an important job here: deforming around your fasteners or around corners. Butyl tape (as well as anything that comes out of a caulk gun) should do a good job of squeezing into nooks and crannies before curing. I did use VHB tape for attaching my solar wire bulkhead feedthroughs (couldn't use fasteners in my 1/8" roof), but I caulked around the outside to form the actual water seal. I used butyl tape for most of my seals and backed up where appropriate with some all-weather caulk.
airdonut41
Images: 28
Postby lfhoward » Mon Mar 21, 2022 10:12 pm
Butyl tape and no leaks since installation in 2016. I recommend putting the butyl tape roll in the freezer for a while before using it, because it is less messy to work with and it unrolls easier than when it is warm.
lfhoward
Postby Minics04 » Tue Mar 22, 2022 6:49 am
I used Proflex RV Clear Sealant.
Minics04
Postby Capebuild » Tue Mar 22, 2022 6:56 am
Thanks all for the help/responses and suggestions.
I think I'll wind up using tube caulk of some variety. I have 4 (or so) tubes of Proflex RV which I should probably not waste. If/when I run out I'll get the OSI clear.
John
Capebuild
Images: 129
