by KCStudly » Thu Apr 04, 2013 5:57 pm
For the rub down through the grits for super fine final finish, yes, but for stripping off the existing finish and smoothing out the rough areas that need repair, I don't think it is that big of a deal as long as you are not using very rough grits (80, 36, etc.).
For the work I have been doing on TPCE, like where the maple cabinet rails and stiles meet, I have not seen a big problem when I have "sanded across the lines". Same thing on the softer cedar sub-frames for the floor, doors and bulkhead. I have used 100 grit almost exclusively, but will probably step down to 220 on the hardwood (with the grain as best that I can) before applying the final finish.
Mind you that I have not applied the finish yet, and I am not a finishing expert by any stretch, so factor that in to your decision.
I'm just saying that it doesn't seem to matter what I do, when I use a belt sander on a big wide flat surface I have problems.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
