Insert type roof edge trim for galley seal.
Re: Insert type roof edge trim for galley seal.
Postby Tommy2tone_1999 » Fri Nov 14, 2014 2:56 pm
This Insert Type Roof Edge Molding on the walls
http://teardroptrailerparts.com/Hinges___Aluminum_Trim.html
Texan, I see you also have 3/4" solid walls on the Armadillo. Did the insert molding have a substantial overhang inside the galley when you used it to help seal the galley hatch. Can you post a pic please? :pictures:
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby Campin' Texan » Fri Nov 14, 2014 11:02 pm
There is a slight over hang on the 3/4" walls. Maybe a quarter of an inch. I don't notice it. I honestly had forgotten about it until you asked.
Here's a pic. It's hard to judge scale though. I also put down some black butyl tape to seal the plywood edge and screw holes. You can see the excess that squeezed out.
Campin' Texan
Postby bobhenry » Sat Nov 15, 2014 7:19 am
Chubby was built for less than $800.00 so I cut a lot of corners. I had a garage door bottom gasket laying around so I cut it to fit and installed it so it would seal against the lexan overhang.
Images: 2617
Postby Hitec4you » Tue Dec 22, 2015 2:36 pm
Campin' Texan wrote:
Tommy2tone_1999 wrote:This post is excellently timed. I will soon be cutting my profiles for the walls. Okay let me see if I get this straight: I can use the t-molding on the lid to over lap the edge of the radius for the galley, and I don't need the offset notch, BUT to do this I need to make sure I get the correct Hurricane Hinge, and I can use a foam insert in the regular edge molding on the radius. Is that right?
If so, which hurricane hinge do I need, which edge modling, which T-molding, and which inserts do I need? Please include the source and part numbers if you can, this will really help me a lot! Thanks so much for this info.
Yes, I believe you have it right. These are what I used on my galley:
This hinge
http://teardroptrailerparts.com/Hurricane_Hinge.html
This T trim on the hatch
http://teardroptrailerparts.com/Offset_T_Molding.html
This insert in the edge trim
http://teardroptrailerparts.com/Neopr_Galley_Hatch_Seal.html
Here's some good pictures from Frank's website that show the set up
I know this has been a while ago that you have posted this. But, I am trying to understand the use of the hinge. The link you sent showed this hinge Image .
I was wondering if you used the bar or not and if you happen to have a photo of your use of the hinge?
I am trying to figure out if there needs to be a little offset for the metal trim that would go on top of the edge of the wall that you would put the bushing in.
Hitec4you
Postby Tommy2tone_1999 » Tue Jan 26, 2016 3:47 pm
I didn't use the bar on mine. I just made sure the hatch match up with the opening edge.
Tommy2tone_1999
Postby Andrew Herrick » Sat Jan 21, 2017 1:37 pm
I use the overhang T-trim method for my teardrops, too. I route out a bit of 2-inch deep wood trim that attaches the perimeter of the sidewall. It fixes the trim overhang issue and, in my humble opinion, makes it easier to fit the final door.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
