by IraRat » Sun Apr 10, 2005 10:26 am
Got you.
And here is the Sunday 11AM update. (No pictures yet, because I was too busy working to take any boring pictures of red metal pieces.)
Here's my assessment:
I seriously hope Kuffel's plans are better as I get deeper into the project, because they sure as heck stunk as far as the chassis assembly goes. I also made a point of e-mailing Kevin there to ask if the modifications were the same for my lighter weight trailer, and he said no difference (except for cutting off 2 little pieces that extend down to accommodate the not used rollers/caster assemblies).
First, the only way to begin with this is to completely assemble/modify the side rails, so you have two full lengths of the sides. Otherwise, it would be next to impossible to drill your holes at a horizontal position on jack stands, as opposed to putting the pieces flat on the grass and drilling down into them. I fortunately figured this out BEFORE beginning any real work, but man, it would have been nice if it was originally explained like this in the plans.
The only pieces that are labeled as to their part numbers are the cross members (2B), and thank God...because by eliminating these from the full list of parts, you can actually figure OUT the identification of the other parts. (It seems like this would be real easy to do anyway, but it would have saved me a half hour if they just could have stuck labels on all of the pieces in China. They could have even done it in CHINESE.)
When you utilize the cross-members to strengthen the rails, you naturally want to center these between the two parts you're joining. However, doing so allows you to use only SOME of the pre-drilled holes already there, but you still have to drill through the other member. In some places, you have to drill through both members, to place your bolts where you know they will do the most good. And yet other holes are good for nothing. I used 6 bolts per left and right joining members, 3 each side.
This means you're left with a darn strong side rail, with a darn lot of bolt heads and holes you would rather not see. So I now know that I'm definitely going to Krylon this, also for the inevitable little scratches you create when handling the pieces. I'm also going to install some kind of finishing piece/molding that can be drilled into the side rails to cover these unsightly heads and holes. This means I have to determine SOON the kind of skin I'm going to use, because that will determine the paint. (I'm leaning toward Woody's floating varnish-covered Birch paneling above. Gorgeous.) Fortunately, these holes and heads are on a pretty narrow horizontal, so even a narrow finishing piece will be adequate.
I wound up using the bolts that came with the kit, because I don't want to spend foolishly yet and they didn't "look" too bad to me. Also, not one twisted or deformed all day.
After drilling a few holes with a high-quality Titanium bit, I took a break and ran to the store to pick up my wood and a different bit, and this new bit worked a thousand times better. Just a cheap B&D black steel bit. (Best $2.50 I ever spent.) It took FOREVER with the "better" titanium one.
Also, when assembling the complete side rails, there was just no way to totally butt the front and rear pieces on one of the sides. I'll deal with this 1/16 to 1/8 discrepancy later, but what could I do? I attached the first bolt to say, the front part. I then drilled the first bolt hole for the rear part, angling my drill to the center so it would later "pull" to the center where they join, when you tighten that second bolt. But on that one side, no dice. The pieces as manufactured were simply off a little.
Next, any novices out there who are going to use this same trailer per these same plans, make sure you have TWO wrachets handy, and cherish them . The bolt heads and nuts are different sizes, and you're definitely going to want to use them simultaneously.
The plans say an impact drill would save you a lot of time tightening the bolts, but I say FORGET it. You're going to be tightening in a lot of different positions/angles, and I don't see how you could handle a big electric thingy in one hand and a wratchet in the other to secure the nut. The wratchets work FINE, except that there are just a few spots where mine wouldn't fit, so I used pliers to hold the nut. (Plus, one of my wratchets got stuck and broke in one of these spots toward the end of the day, so off to the store again for me!)
Next, the wooden cross member you have to install:
The plans make no sense here at all. You can't knotch that piece to sit flush with the top of rails, because it would only be like 1/16 thick, so what good is that going to do? It also wouldn't be flush, so I think this refers to the heavier duty trailer with a flange. You don't later actually notch the members of the floor frame for this, right? Wouldn't that be a little ridiculous?
Also, the plan's dimensions for this piece of wood were wrong for my trailer, and I couldn't find what seemed to me to be the RIGHT dimensions of douglas dry (or other wood) at Home Depot. So since I know I don't yet have the tools nor skills to cross-rip a 4 X 4 vertically to the exact proper height, I did this:
I purchased two 8-foot lengths of 1 by 6, cut them to approximate length, and sandwiched 3 pieces together using Elmer's Polyurethane Ultimate Glue. (I bought the big bottle, because I know I'm going to use a lot of this in the weekends to come.) This assembly is dry today, which I'll finish up with some wood screws and utimately place screwhead side down. I'm not installing the floor hatch, so I didn't have to worry about going a bit wider on this wood.
I made an engineering "guess" here because this wooden cross member's purpose is for floor support and as a spreader for the side rails. Heck, the plans don't even call for ATTACHING this to the steel. Also, I've always heard that several pieces of wood properly glued together are stronger than one piece anyway.
The only problem I have is that I'm still like 1/16 short on the height. I'll probably glue an additional laminate thickness piece of wood on top for a true flush with the side rail, as opposed to shimming it up a little.
Anyway, I spent a lot of time on this yesterday, but I actually DIDN'T when you consider everything and where I am. Not only did I get a late start, but there were a few trips to the store involved, and I had a few errands to run as well.
So it's "kind of" assembled sitting on the jack stands now, with the vertical bolts mostly tightened but the bolts that go in on a horizontal (except for the side rails, of course) NOT tightened. These are going to determine that I get the true 4 X 8, and even though the vertical bolts play a part in this, they will "give" as a I tighten the side ones. I also just this second made a decision to NOT tighten it until my floor assembly is completely done and protected with asphalt coating on the underside:
It seems to me that the ONLY way for me to get my true 4 X 8 on the chassis (I'm terrible with this task) is to place the complete floor assembly there first, bolt one or two corners to the steel, and start tightening the side bolts. I might be totally off on this (your thoughts?) but I can't see any downside to doing it this way.
Axel assembly? I'm glad you asked:
It got dark, so I took these parts inside to take a look and figure it out.
Duh???????
I give Kuffel's plans an F here, but I can't rate Harbor's poorly because their instructions include all of that fold and roll assembly. I know that I don't NEED all of those parts, but is there one that I DO need? Like I'm not using the supplied fenders, so I don't know if I need to install one of those brackets/parts for the fenders I ultimately decide to use. Only another day in the backyard will determine that. Also, I simply don't "get" Kuffel's illustrations on the axle assembly. They even appear to have the spring mounted upside down as compared to Harbor's. I wish I could see a photo of how this is supposed to look.
Help? Anyone?
I have a bunch of computer work to do today, and I think that's a good thing. Slow and steady is going to win the race for building this right, and I don't want to make any rush, "My back is killing me" decisions. I was even going to run to the store again last night to buy a new wratchet set and a few new bolts that Kuffel says I'm going to need (without indicating the size), but I came to my senses.
Tomorrow's another day, and it will eventually get done.
Thanks for listening, guys, and if you see anything above that might mean my ultimate, grizzly death and the deaths of countless innocents, please let me know. I also hope that my lengthy diary here will help some new builders with limited abilities such as myself.
--Ira
