Re: Framing for trailer with rooftop tent
Posted: Wed Mar 31, 2021 12:00 pm
You also have a nice Home to keep that crazy white stuff off.
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
Tom&Shelly wrote:twisted lines wrote:I Should be painting the flat roof on mine this week, I already know it's going to puddle
When I glued the roof on and put a few hudddous on top when it qured, there is a low....
We have the same problem with our teardrop. Luckily, I have GERD, so we'll be cranking the front up a few inches, so most of the rain should run off onto the galley hinge, and then down one side or the other.
We hope!
tony.latham wrote:ptulli wrote:Would making it like a "#" idea be enough for the cross blocking/framing then?
I'm not sure what you mean.
There's no reason to put blocking between hatch spars since the sheathing acts as a gusset. If that is what you are asking.
I've never built a flat-backed camper. The problem that I would anticipate is keeping the hatch from twisting.
Though I may need some for where the lights will go...
tony.latham wrote:Though I may need some for where the lights will go...
This is how I add blocking for the light and exterior fixtures inside the hatch.
As far as hatch clearances, I use 1/8" on the side. But you need to figure out your seal system first and your hinge. I think you need to explore what others have done for flatback hatches.
JanetSnow wrote:Sounds like a really cool project. Have there been any updates since then? When it comes to framing the walls and roof, using a combination of materials could be a good idea. While 1x1 metal tubes can provide extra strength, you might want to consider using them strategically in areas where the weight distribution is crucial. This can help ensure the overall structure is sturdy without adding unnecessary weight.
