removing rivets
removing rivets
Postby Ron Dickey » Wed Oct 06, 2004 5:17 pm
121377......134179
Ron Dickey
Images: 711
Postby D. Tillery » Fri Oct 08, 2004 7:01 pm
Speaking of rivets. Does anyone know where to get the things that hold your pieces and holes in line temporarily while you put in the rivets. I have seen them in WW2 museums. They look kinda like metal syringe. D. TIllery
D. Tillery
D. Tillery
Images: 9
Postby asianflava » Fri Oct 08, 2004 8:59 pm
Clecos? Any aircraft supply place has em, I've also seen them in racer catalogs too.
http://www.aircraftspruce.com/catalog/topages/sheetholder.php
You will probably want to get the cleco pliers too. Notice they have pricing for 50 and 100 pieces. It takes a lot of clecos to make airplanes, we had a bucket full of them at school. By the time everybody got their shop projects going, the bucket was looking pretty empty.
asianflava
Postby D. Tillery » Sat Oct 09, 2004 10:13 am
Yep, that's exactly what I was asking about. And every time I have seen them before they were in use by the hundreds. Cheap too! They will definitely come in handy for riveiting on trim.
Do you need the pliers to insert/remove them or can you do it by hand?
Thanks, D. Tillery
D. Tillery
D. Tillery
Images: 9
Postby asianflava » Sat Oct 09, 2004 12:07 pm
There are special pliers for them. The spring pressure is too much to do it by hand. The pliers are relatively cheap. I found this auction http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11805&item=3844833223&rd=1
asianflava
