Page 1 of 3
Portable Belt Sander 101
PostPosted: Wed Jun 20, 2007 12:19 pm
by Roly Nelson
Is the belt sander a noisy, dusty, expensive, heavy, dangerous, and probable ruiner of fine woodworking projects? NO! This is a wonderful time-saving power tool and when understood and operated correctly, can make difficult sanding problems a thing of the past.
First we must be familiar with the simple mechanics that make the sander do what it does best......Sand. There are only 2 moving parts that one has to be concerned about, the rear drive roller, the front idle roller. Between these, is the stationary bottom skid plate. Tracking of the belt is accomplished by turning the tracking knob, located close to the front idle roller. With the sander on and held away from material, turning the knob will noticeably move the belt from side to side. The ideal position of the belt would be to make it flush with the left side of the skid plate. The sander can be damaged if the sanding belt is allowed to track off to the right side for any length of time where it can destroy the metal rub strip and ultimately the sander.
Prior to actual sanding, some precautions should be mentioned. Loose clothing or unbuttoned sleeves are a no-no. The dust bag should be emptied, and the location of the power cord should be monitored during sanding, since running over the cord usually ends up with it being wedged between the rubber drive roller and the sanding frame. Been there, done that. Next, most sanding belts have a rotation arrow printed inside, but some lack this feature and seem to work just fine regardless of how they are installed. The belt travels counterclockwise and can be easilly be inserted by releasing the tension lever, which moves the front roller and loosens it enough to slip the belt into place, then snaps tight to secure it. Check tracking after all belt changes, especially if sparks are occur due to improper movement against the rub strip.
Now we must decide what grit of belt to use. I like to have a good supply of new belts on hand, ranging from course (50 to 80) to fine (100 and up). Aggresive removal requires course belts, and here is where the trouble usually starts. New belts cut fast, yet the same grit that's well worn, removes less wood, is easier to control and after initial sanding, I often change to a less abrasive one.
A few words about the placement of a loose work piece prior to beginning. The stock to be sanded must be made immovable to prevent it from flying off the workbench. When I sand the surface of a flat board, I install a stop-block at the end that is a bit lower than the work piece. The sander wants to push the board backward, and the stop-block prevents movement. When sanding the edge, I mark it with cross-wise pencil marks and secure it in a bench vice or any other suitable clamping device. The trigger lock on sanders, in my opinion, should never be used. My trigger-finger is never too tired to squeeze it, and I don't want it racing off the work table when I plug it in. However if you are having a "sander race" with your neighbor and his sander, the trick is to lock both triggers and plug them both into a switched outlet, flip the switch and let the race beguin! Hmmm just like we did in high school wood shop.
Now comes the fun part, sanding the wood. If needed, I prepare the surface with the tell-tale pencil marks to determine where wood is being removed. I usually start the sander in mid air, letting it float onto the wood with just a little pressure, often not allowing the full weight of the machine on the belt right away. Using long, flowing strokes, monitor the gradual removal of the fading pencil marks. With a little practice, putting an ever-so-slight pressure on either the left or right side of the sander, the entire surface can be sanded uniformlyand all marks removed. The lengthy strokes should terminate with 1/2 of the sander extending over the end of the work piece, being careful not to 'nose-dive' it at either end of the stroke. This can be followed up with a finer grit belt, using the same proceedure. If extreme amounts have to be removed, more downward pressure or sanding crosswise to the grain will result in greater material removal then followed by with-the-grain strokes to do away with objectional cross-sander marks.
Don't fall in love with the belt that is in the sander, change belts accordingly to obtain the required finish. However, I usually keep a supply of "worn" belts to use when I want to remove paint. When sanding off old paint, I don't use long strokes but start at the front end of board, slowly sanding backward, allowing the rear roller to attack the painted area first. This allows it to remove and lift the gummy paint and pitch it behind the sander and reduces the clogging of the belt. I generally slide the sander from side to side and continue down the length of the board while removing paint. Of course when the paint is gone, normal steps listed above can be followed, and Bingo, you have a new board.
Now, the size of the sander itself. During my production work I used large, heavy, 4" wide beltsanders requiring both hands to operate. They can run longer without heating up and are more powerful and aggressive. After scaling back to my do-it-yourselfer projects, like my Woody Teardrop, I have found that the lighter the sander the better. Also, 4 x 24 belts are more expensive than the 3 x 18 size that I use now. Sometimes, I must hold the sander in one hand, and the big ones are just too heavy.
I have found that some foreign sanding belts are a smidge too big and they will slip if the front roller isn't tight enough against it. There are 2 methods I have used to solve this problem. One is to wrap the front idle roller with a few layers of duct tape and the other is to add a 1/4" secondary wood skid plate, and both methods work fine. Also, when sanding the inside of curved ribs, as in galley hatch, I cut a matching curved skid plate which allows sanding this curved surface easilly with no flat spots. Ocasionally I sand with just the front roller on a very tight inside radius curve, but this can be distructive if not done carefully.
When sanding intersecting wood members, as on the face frames of cabinets, I sand the intermediate members first, using the pencil mark trick, then finish off the longer, outside members, carfully watching the edge of the belt so it doesn't cross onto the adjoining cross-grain member. This move takes a tender touch, but that is what belt sanding is all about. It's quite a bit different than sanding down a big, gnarley 4 x 12 timber that will get stained in the ceiling of the great room.
In cabinetry, I have edge-banded walnut, birch, oak and ash plywood panels, with solid wood members that match the veneer of the plywood. I cut the solid edge members slightly wider than the plywood and when glued to end grain of the plywood, I sand it down to the flush surface of the plywood. To do this, the old pencil trick is involved again, and of course a very fine grit of sanding belt. One mistake in this process, and it becomes firewood. Often the edges of raw plywood must be sanded, such as cabinet doors or shelves. To accomplish this, I place the plywood flat on a low work bench, kneel on it, place the sander on it's side, start it in mid air then slowly engage the belt surface, in long, even strokes. Progress is checked with a square and more or less pressure is exerted as needed.
I am sure many accomplished belt sander users have even more tips to that could help us all become more proficient with these multi-use portable machines. If so, share them with us and if you take exception to any of my pointers, be sure to let me know as well. It is advisable to wear a dust mask and of course it would be nice to have an adequate dust removal system, but I have a covered, outside sanding area and the wind blows the dust into the neighbors yard....... :-)
Roly, just my 2 cents, and I hope this sheds a little light on successful beltsanding for everyone. :lol:
PostPosted: Wed Jun 20, 2007 12:39 pm
by madjack
...excellent job Roly...told with your wit and style it makes for an informative read...thanks for your effort... :thumbsup:
madjack 8)
PostPosted: Wed Jun 20, 2007 1:00 pm
by Miriam C.
Thanks Roly, wonderful read. :thumbsup: Wonder how many cords get run over the first time out. :oops: :lol:
I'm a bit slow :roll: You wouldn't happen to have a picture of this? :twisted:
PostPosted: Wed Jun 20, 2007 1:28 pm
by Mary K
Thanks Roly!!! :thumbsup: :applause:
I had flashbacks of my shirttail getting caught up in my sander. :o
Mk
PostPosted: Wed Jun 20, 2007 1:36 pm
by apratt
Like I said I won't say no to a pro because there is alway something a person can learn from another pro. I liked what you said about going backwards for removing paint, I didn't know that :thumbsup: I do have one question, now I am more familier with air boards, when you are using the belt sander and sanding with the grain do you have the belt sander at an angle as not to dig a trench??
by khutson
Thanks for taking your time to write it up. I have new belt sander and used it the other night. I will have to incorporate your technique to get the best use out of it.
Ken
PostPosted: Wed Jun 20, 2007 1:57 pm
by Podunkfla
Good job Roly! :thumbsup:
About the only thing I could add is using a belt sander cleaning stick fairly often will extend the life of your belts and let them cut better:
http://www.rockler.com/product.cfm?page ... okietest=1
I also sometimes clamp a wirebrush in a wood vise with the bristles sticking up and then I can safely run the sander over it to clean off those nasty little seeds that stick to the belt. This works well for random-orbit sanders too.
PostPosted: Wed Jun 20, 2007 2:13 pm
by Mary K
Oh, I have clamped my sander to my workbench and clamped the trigger (no trigger lock) for some small detail wood work. I'm sure there is a fancy piece of equipment to do this for a real wood shop, But hey, learn to work with what ya got huh?
Like this...
To make a stand off for my sink spigot
Mk
PostPosted: Wed Jun 20, 2007 5:00 pm
by Roly Nelson
Arthur, I have absolutely no idea what an air board is. Can it be that I have been out of the loop so long that it hadn't been invented before I retired? Now as to your question of sanding with the grain and digging a trench in the wood, if that happens, you are doing something improperly. First, NEVER hesitate in one spot with the sander running. Always keep it moving, preferably forward and back.
Really, I know it sounds like a small thing, but putting crosswise pencil marks, and sanding them down uniformly assures success. The only way to dig a trench while sanding a board is to have a sanding belt that is way too rough and/or you are pressing down too hard on the sander to make it sand faster. Fine belt sanding is a tender act, treat the object of your affection (your work piece) like you would treat your best girl friend, oh, so tenderly.
I always sand exactly with the direction of the grain, never running the sander at an angle, unless I am smoothing up an old rail road tie. The sander will do all of the work if given a chance, and as I said before, too course a belt and improper pressure could be the culprit. Now, fire up that big, bad, blasted, belted behemoth and have a ball.......but remember, delicately.
Float like a butterfly and sting like a bee......Roly ~~
PS, Now, just exactly is an air board??
PostPosted: Wed Jun 20, 2007 5:19 pm
by Roly Nelson
Mary K, that was a good idea to clamp your belt sander down to use it as a stationary sander. I've done it many times, but I failed to mention that in my epistle because I have a huge 6" belt and 12" disc sander combination that I use for that kind of work. That multi-ply wooden member looks good under that faucet. See, without a belt sander, it couldn't have been done so easily.
Isn't it amazing how we can adapt various tools to do seemingly near impossible jobs? Once on a jobsite, I screwed my skil-saw to a plywood board, flipped it over and used it all day as a table saw. Probably didn't do it any good, but it worked in a pinch.
Roly :twisted:
PostPosted: Wed Jun 20, 2007 5:53 pm
by apratt
Sorry Roly, sometimes I forget and take for granted that everyone knows what I am talking about. Airboard is a boldy & fender repairman term for a air tool, its correct name is airfile. It is an air tool that is about 3" wide x 17" long that the part where the sandpaper attach to it mooves about 1 1/2" forward and back. When I use it on cars to sand the bondo down. I never move it straight line, always at a cockeye angleabout 2" offset to avoid making a trench and to make my surface flat. But really on most cars there is no such thing as flat, everything has a curve. Also I don't have wood grain to deal with. :lol: thanks for educating me on the belt sander. :thumbsup:
PostPosted: Wed Jun 20, 2007 7:56 pm
by Arne
When I cut the tear drop curve in my tear walls, I first roughed it with a skil saw (4 pieces pinned together).. then I used the belt sander.. it was going real slow till I just used the wheel at the front.. that ground it away pretty quick..
As I neared the curved line, I'd use the flat of the sander and like above, kept it moving to avoid flat spots.... worked out well...
And Roly, thanks for your time.. that is quite a write-up you did.....
PostPosted: Wed Jun 20, 2007 9:33 pm
by Mary K
Roly Nelson wrote:Mary K, that was a good idea to clamp your belt sander down to use it as a stationary sander. I've done it many times, but I failed to mention that in my epistle because I have a huge 6" belt and 12" disc sander combination that I use for that kind of work. That multi-ply wooden member looks good under that faucet. See, without a belt sander, it couldn't have been done so easily.
Roly :twisted:
:thumbsup: I WISH I would have thought of doing the skill saw (circular saw) thing earlier in the build. But its no to late, I still have exterior trim to do.
:thinking: Got any ideas on making a planner out of the belt sander? I can not find 1/4" thick boards for the top trim...still... ;)
Mk
PostPosted: Wed Jun 20, 2007 9:51 pm
by Roly Nelson
Mary K, if you have a table saw, a good sharp carbide-tipped saw blade will rip a 1 x 3 when flipped up on edge to any thickness you set the fence to. Actually you can make 1/4 inch boards up to 5 " wide if you rip it from both edges. Then the trusty band sander takes over and you have wonderful 1/4 inch stock with no planer needed. I do this all the time when I want thinner drawer sides made from thicker stock.
Just my too scents, or something like that.............Roly ~~ :)
PostPosted: Wed Jun 20, 2007 10:02 pm
by Miriam C.
:twisted: Wonder if I can get my circular saw to go in the fried table saw. :twisted: would sure make the trim easier.
