I recently completed my Cubby build and before I took it out for a low flying test run, I jacked it up and pulled the axle hubs, as everyone should do with a new trailer.
To my surprise and dismay, the hub was full of metal shavings and the inner bearing had ZERO grease in it. The metal shavings were coming from the improperly installed cotter pin for the axle nut. It was bent in such a way that it was rubbing on the inside of the dust cap and shaving the metal from the inside of the cap. It had completely contaminated the grease in the outer bearing and that was just from rolling it around in the shop. Both sides were the same. Towing a trailer with these problems would cause serious axle damage and could cause the hub to seperate from the axle, which would be a major bummer. So, if anyone has a Harbor Freight trailer, pull your hubs and check them out.
Anyway, I cleaned and repacked the bearings, installed the cotter pin correctly, and hit the road. Pulls straight as an arrow at 85 mph.( behind my diesel truck)
Here is my Cubby
My Galley: All oak cabinets with aluminum trim
