GregJ wrote:Just my 2 cents, having never built a tear. Please consider the source.
Both methods appear to have been used and work, so that’s not really an issue…
Cost- a sheet of ¾ ply is about $22 around here, enough hardwood to
frame a side maybe twice that (? or more).
Time- I can cut holes a lot faster than cut and fit for a stick frame.
Those “skilled in the art” may be able to frame as fast. Lindsey
says an hour for the holes, that’s about 3 sticks for me.
Strength- Depends on the structure but with the ply you can beef up the
areas you are concerned about. Also much easier to do a 2D
web with the ply and no joints.
Weight- Either can be over or under done. In our world stick is probably
lighter. Well Engineered, the ply probably is (more design
freedom) but I am guessing here. I’d call it a wash or give the
edge to stick and bow to an ME with data.
Hinges- Wouldn’t use edge mounted hinges directly in ply myself, but
epoxy on the end grain would help a lot. Would be easy to let in
a piece of hardwood for the door hinges: T&G and covered both
sides with sheathing would be as strong as stick. A hinge that
through mounts should be fine, again, I’ll bow to those
experienced. Ply tends to warp less.
Wiring- A ½” hole in ¾ material will not help either; I really don’t see
an advantage either way.
GregJ wrote:Salivanto,
If I understand your question, IraRat and asianflava are correct. Also note, the hardwood in the plywool is only a very thin layer and mostly for looks.
Salivanto wrote:Anybody here every been too cold in an uninsulated tear? How about one with an insulated roof but uninsulated walls?
Users browsing this forum: No registered users and 27 guests
