lmh222 wrote:Yeah, mine was on backorder for over a month when someone on this site suggested that I check out the harbor freight "brick and mortar" retail stores.
Georgeandpat wrote:As I recall, this frame was pretty heavy and came in two boxes. If your going to pick it up you might want to make sure your vehicle has room and someone to help lift it. George.
IraRat wrote:Yep--defintiely hernia time. Even my LIGHTER one.
(The boxes aren't that huge, so I think you'll be able to get them into a "norma" car with "something" sticking out.
exminnesotaboy wrote:IraRat wrote:Yep--defintiely hernia time. Even my LIGHTER one.
Just a second opinion to the one above - I agree that they are heavy, but there is no way that I could have fit the larger of the two boxes in any "car" that I have owned.
the bigger box is crated in wood and is approximately 14" x 12" x 6.5' long and approx 150-200lbs. I think the car could handle the weight, but if it was "sticking out", the pressure of the "out" part would probably have to rest on a trunk seal - definitely not good
just my $0.02
toypusher wrote:you can usually rent a pickup at most places like National, Enterprise, or even HomeDepot and U-Haul for about $20.00.
Kerry
