I am in the process of building the little unit. I am going to use luan on the top and plywood for the sides. I am going to use fiberglass epoxy on the sides and top. Can I just use the epoxy without using the fiber? What would you suggest filling any screw holes with before I apply the epoxy? What is used to clean up a brush after applying the epoxy?
Thanks for any help
