Page 1 of 1
FRP for my Ceiling
Posted:
Thu Mar 02, 2017 10:39 pm
by IndyTom
I am ready to install my ceiling. I built my walls leaving a ledge, like I learned from someone here, just can't remember who. My first thought for a ceiling material is FRP. It is flexible, to fit my profile. It is fairly easy to work with. And it is very durable. I am looking for thoughts. I do have an area right at the top of my profile that is pretty flat and I am a little afraid the the FRP will sag in that area.I will be glued to rafters above it, just not sure that will be enough. Anyone? Ideas? Opinions? My profile is in my build thread, linked in my signature
Re: FRP for my Ceiling
Posted:
Fri Mar 03, 2017 6:29 am
by JaggedEdges
My thought is, if it's the same panel that is bent either end, on even a very shallow curve or short flat area it will put some tension in it. But if the flat panel is on it's own it may sag a tad, not going to sag in an unsupported foot probably, more like just noticeable in 2 feet.
Posted:
Fri Mar 03, 2017 9:51 am
by Graniterich
I have built fourteen with frp panels. I clamp One end, and shove up against the spars, mark with pencil, remove tension and use PL roof flashing adhesive. I found it by accident, allows up to 30% movement (just means it is not brittle) . Wait two days to dry, and done. No ledge, just adhesive, impossible to remove!
Posted:
Fri Mar 03, 2017 10:30 am
by IndyTom
Thanks for the replies guys. Sounds like I made a good choice. The large majority of the ceiling has at least a small curve to it. The flat area is about 20 inches long and 80 inches wide, but I will have spars/rafters at least every 12 inches. I want to be able to walk on that part of the roof so they may be every 6 inches, so it seems that the FRP panels will be well supported. Now I get to stop at Menard's on the way home and pick up my panels and get started installing them!
Thanks again
Posted:
Fri Mar 03, 2017 11:33 am
by KCStudly
I used 5mm ply for my ceiling, which also rested on the tops of my walls (ledge like). On test fit it did sag a bit with no support, even tho my roof profile has a crown in it. I didn't like the idea of having to supply and make a bunch of prop sticks (which seemed like a lot of wasted material and time) so I came up with a simple clamp method and glued roof spars onto the top of my ceiling skin prior to installing it all as an assembly. No sag, no prop sticks, no working over my head in a cramped space.
http://www.tnttt.com/viewtopic.php?f=55&t=48630&hilit=ceiling+spars&start=2085#p1085422
Posted:
Fri Mar 03, 2017 12:51 pm
by linuxmanxxx
The new NRP panels would be better since it's inside and are extremely lighter and even cheaper than FRP. I know Lowe's carries them not sure about HD.
Sent from my Nexus 6P using Tapatalk
Posted:
Fri Mar 03, 2017 5:06 pm
by IndyTom
linuxmanxxx wrote:The new NRP panels would be better since it's inside and are extremely lighter and even cheaper than FRP. I know Lowe's carries them not sure about HD.
Do tell, I was about to leave for Menard's when I read this. What is NRP? Is it as flexible as FRP? As durable?
Going to hold off for the time being.
Posted:
Fri Mar 03, 2017 5:39 pm
by greygoos
NRP is very lightweight and about half the thickness of FRP. It is 19.00 a sheet here in Syracuse. I have used it on food trailers. I used PL premium but found I had to spread the entire sheet with a notched trowel. In "my" experience just dabbing it on in spots caused what looked like bubbling after it dried. It was quite a job ripping it off. It is thin like a disposable cutting board.
Posted:
Fri Mar 03, 2017 5:49 pm
by linuxmanxxx
It's the same pebbled plastic without the fiberglass embedded so thus is massively lighter and same exact look.
Posted:
Fri Mar 03, 2017 6:39 pm
by IndyTom
Thanks again everyone. I just got checked and Menard's sells it. Will be picking some up later tonight.
Posted:
Fri Mar 03, 2017 7:39 pm
by razorback
I found that using a shear is the best way to cut FRP. I had not discovered the forum when I was building my TD. Couldn't find Aluminum locally so I discovered a salvage yard that had rolls of FRP that were 82" wide. I had planned to cover all of the outside with FRP but the price was so low I also did the inside walls and floor too. I covered all my walls and floor for 108.00. The electric shear made all the cuts smooth and easy. 34000 plus miles later I am happy with my decision. Good luck on your installation.
Larry
Posted:
Sat Mar 04, 2017 1:55 pm
by IndyTom
Thanks Larry,
That is a great looking build you have there. I am going to have to get a set or either electric or pneumatic shears, I keep coming across little jobs where they would work so perfectly, but that is one tool I have just never bought. Safe Travels
