Advice on door and hatch seals?
Postby harryrauser » Tue Jul 04, 2017 3:36 am
Hello all,
I recently bought my first teardrop trailer, a self-build from a craftsman from my area. It's great but it isn't watertight alas. I am trying to figure out what might be the best way of remedying that. I've been browsing through related forum posts and found a few interesting inspirations. Hope you don't mind me asking your advice regarding my particular design. How would you go about it? Please have a look at this video I made to show the details.
https://www.dropbox.com/s/wujb2zfapmn9h ... s.mp4?dl=0
Thank you very much in advance!
Screenshot 2017-07-04 10.54.34.jpg (205.98 KiB) Viewed 1826 times
harryrauser
Re: Advice on door and hatch seals?
Postby Trevor57 » Tue Jul 04, 2017 9:34 am
That door should have a gutter above it. https://www.google.com/search?q=trailer ... 66&bih=659 It is an easy fix, and will possibly fix the problem.
Trevor57
Images: 24
Postby steve cowan » Tue Jul 04, 2017 9:56 am
Nice looking camper you got.Definately a gutter over door.Also when hatch is open during rain a diverter of some sort will keep water out.ideally the hinge and rubber seal
should have extended 3/4 to 1 inch past the sides to prevent leak into hatch.
steve cowan
Images: 207
Postby harryrauser » Wed Jul 05, 2017 2:40 am
Thanks for the suggestions. I will definitely try and find gutters or have some made. Do you think I should add some exterior covering of the gap? Something to overlap the wall so I would have room for another set of sealing?
harryrauser
Postby Esteban » Sun Jul 16, 2017 9:40 pm
!. Install better Door Hatch Seals on the inside surrounding the door.
2. Install a Drip Cap on the exterior above the door(s).
3. Install a Hurricane Hinge to the galley hatch that protrudes about 1/2" to 1" beyond the exterior walls.
I looks like you live in the UK. Are these or similar parts available to you?
Steve - SLO, CA
Esteban
Images: 15
Postby harryrauser » Sun Nov 19, 2017 2:41 am
Hello Esteban, thanks! I did put in better seals, that helped. A drip cap like this would be great, I think that would make all the difference. Unfortunately my door has a curved top edge so the straight drip caps won’t work. I’ll contact that place to see whether they could customise one of these. - no I live in Germany, I have not seen that type of drip cap around here...
Gesendet von iPhone mit Tapatalk
harryrauser
Postby greygoos » Sun Nov 19, 2017 6:45 am
I have used trim lok gutter with some success. https://www.amazon.com/Trim-Lok-DRB-25- ... B06VWRJZ3W.
trim lok.jpg (12.44 KiB) Viewed 1235 times
greygoos
Users browsing this forum: Bing [Bot] and 34 guests
