Trimming a woodie.
Trimming a woodie.
Postby edgeau » Sun Aug 13, 2017 5:24 am
I am not doing an aluminum skin. I have now successfully got a nice looking roof on but l am looking for ideas to hide the ply edge with some sort of trim. What have others done?
Sent from my Pixel using Tapatalk
edgeau
Re: Trimming a woodie.
Postby TomMaj » Sun Aug 13, 2017 7:27 am
I cut some poplar to 1/4" x 2 1/2 inch strip, then screwed it on with brass screws and washers, leaving 1/4" overhang for a drip edge. epoxy and varnish over it.
new wheels 02.jpg (733.7 KiB) Viewed 638 times
TomMaj
Postby Viking_Tear » Sun Aug 13, 2017 8:40 am
TomMaj wrote:I cut some poplar to 1/4" x 2 1/2 inch strip, then screwed it on with brass screws and washers, leaving 1/4" overhang for a drip edge. epoxy and varnish over it.
That is absolutely stunning, well done.
Sent from my Nexus 5X using Tapatalk
Viking_Tear
Postby drhill » Sun Aug 13, 2017 8:48 am
like you, I had to cover the edges of the roof plywood. I ripped thin pieces of birch and glued it to the sides. Then routed and sanded the edges flush with the roof surface before finishing. Has held up well so far (3 years) but does get a few fresh coats of poly every year.
150129
drhill
Images: 35
Postby jamie296 » Sun Aug 13, 2017 10:48 am
Anyone have build threads on these? I am looking to build one of these woodie versions with the vintage look to it.
Sent from my SM-N920P using Tapatalk
jamie296
Postby Woodbutcher » Sun Aug 13, 2017 3:26 pm
Not sure if this will help you, but here is what I did. Has worked great.
viewtopic.php?f=50&t=48321
Woodbutcher
Postby edgeau » Sun Aug 13, 2017 4:47 pm
Beautiful work
edgeau
Postby edgeau » Sun Aug 13, 2017 4:49 pm
drhill wrote:like you, I had to cover the edges of the roof plywood. I ripped thin pieces of birch and glued it to the sides. Then routed and sanded the edges flush with the roof surface before finishing. Has held up well so far (3 years) but does get a few fresh coats of poly every year.
150129
Nice. Did you curve the bottom edge with a jigsaw first?
edgeau
Postby edgeau » Sun Aug 13, 2017 4:51 pm
150129
Actually when I zoom in I see better that it isn't curved like I imagined. Looks good. Well done
edgeau
Postby Nobes » Thu Aug 31, 2017 1:37 pm
I used aluminum edging I bought from vintage technologies.
Nobes
Images: 508
