Flexable wood filler.
Postby dancam » Wed Sep 06, 2017 6:04 pm
Hi, is there a flexable wood filler available? I built a tongue box for my trailer out of 1/8th plywood. Made 2 mistakes. One was we glued one part on rough side out and the other was it was made 4inches too wide so i had to cut 4inches out of the middle.
What i would like to do is seal the whole thing with 'the mix', let that dry, fill the knots and seam that is in the photos with some flexable filler, then paint it.
The tongue box will flex a lot so rigid filler will crack and pop out. The filler also needs to have decent enough adhesive properties to stick to sanded 'mix' and be paintable.
Testing lepage no more nails interior gap filling adhesive and exterior 'mono' caulking on some scrap pieces right now.
Thanks for any help!
Last photo was before cutting it in half...
dancam
Re: Flexable wood filler.
Postby tony.latham » Wed Sep 06, 2017 6:30 pm
I think what you need to do is see if you can't delaminate a piece of scrap birch and cut this thin laminate into into a football shaped piece that you could inset into your knot area. Just like a football patch in a sheet of plywood. I would think would be doable with an Exacto knife and a small chisel.
Postby featherliteCT1 » Wed Sep 06, 2017 7:33 pm
Nice looking box!
featherliteCT1
Postby dancam » Thu Sep 07, 2017 12:37 am
tony.latham wrote:I think what you need to do is see if you can't delaminate a piece of scrap birch and cut this thin laminate into into a football shaped piece that you could inset into your knot area. Just like a football patch in a sheet of plywood. I would think would be doable with an Exacto knife and a small chisel.
Ok, thanks. Ill try that on the knots and see how it goes. Should work i would think. Any suggestions for the seam?
featherliteCT1 wrote:Nice looking box!
dancam
Postby tony.latham » Thu Sep 07, 2017 7:40 am
How are you going to finish it? I'd toy with using a thickened epoxy and make sure it's squeegeed level. I assume there's wood behind the joint?
Postby dancam » Thu Sep 07, 2017 7:59 am
tony.latham wrote:How are you going to finish it? I'd toy with using a thickened epoxy and make sure it's squeegeed level. I assume there's wood behind the joint?
Just how i had said in the first post- coating with the mix and then painting. Using exterior latex paint is the plan.
I have some epoxy which is super thin, what do you thicken it with? There is wood behind the seam but i am still worried about something rigid like epoxy cracking away from the sides as the wood flexes. Or would that not happen?
Thanks
dancam
Postby tony.latham » Thu Sep 07, 2017 8:03 am
Thanks
If there's that much flex, they make some flexible caulks you may want to use. There are several fillers specifically made to thicken epoxy but in a pinch sawdust works.
T
Postby Esteban » Thu Sep 07, 2017 2:10 pm
I'm a proponent of using fiberglass, i.e. epoxy and fiberglass cloth. PMF (poor man's fiberglass) may be good enough for you needs. You can fill the plywoods knots and defects after you bend and install it, then reinforce the plywood with fiberglass or with painted PMF for longer time durability.
If you choose to use epoxy to fill the plywood joints and defects you can thicken the epoxy with sawdust or Cabosil (fumed silica powder). An electric sander with a filled up sawdust bag might be your source of finely textured sawdust. Cabosil is inexpensive
Steve - SLO, CA
Esteban
Images: 15
Postby dancam » Fri Sep 08, 2017 1:21 pm
Thanks
T
Its just 1/8th plywood, so the top flexes a lot. The curved sides dont though.
Ill have to look at different caulking, the one i tried dried way too soft.
dancam
Postby dancam » Fri Sep 08, 2017 1:24 pm
Esteban wrote:I'm a proponent of using fiberglass, i.e. epoxy and fiberglass cloth. PMF (poor man's fiberglass) may be good enough for you needs. You can fill the plywoods knots and defects after you bend and install it, then reinforce the plywood with fiberglass or with painted PMF for longer time durability.
Thanks, the issue with doing pmf is the compound curves on the lid. I had just wanted this done quick and figured this would be easy so i never looked into fibreglass. Should have just made a quick foam mould, made a fibreglass tongue box over it and pulled the foam out and been done.
dancam
Postby Atomic77 » Mon Sep 11, 2017 4:13 pm
Use 3M body filler. I've used it in such circumstances many times. I would suggest against thickened epoxy, not that it won't work because it certainly will. It's just much harder to sand. We use filler on plywood a lot in the boat shop and on molds for parts. Check out the walls of my build in my build journal for a few pointers.
Sent from my SM-N950U using Tapatalk
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby Atomic77 » Mon Sep 11, 2017 4:19 pm
Here's what we use. Its flexible and has built in adhesion promoters. Its pricy but if you keep it sealed and away from freezing temps, it will last a long time. It's Pro-quality and we use it on million dollar boats on the regular.
Michael
The Astroliner
Atomic77
Images: 309
Postby kielyjw » Wed Nov 15, 2017 4:43 am
Bondo or body filler works great also durabond drywall powder works great. You must get the durabond in the brown bag not the white bag. Brown bag sets up like a rock where as the white bag dries to the easily sanded dusty powder. The brown bag is also waterproof.
kielyjw
Users browsing this forum: No registered users and 36 guests
