materials other than ply for hatch/curved panels?
Postby mboardman » Mon Sep 25, 2017 8:56 am
Id like to hear about sourcing and bending 4x8 or similar sized materials for the curved areas like the galley hatch, etc. Anyone use a plastic or synthetic instead of wood? Then covering it with alum sheeting as normal?
I live in KC and having trouble finding sources for the common plys people here seem to use...baltic birch ply or luan or purebond stuff. Im leery of ordering something without seeing it.
Any ideas?
-- Kansas City
mboardman
Images: 5
Re: materials other than ply for hatch/curved panels?
Postby tony.latham » Mon Sep 25, 2017 10:43 am
I live in KC and having trouble finding sources for the common plys...
Try calling a couple of cabinet shops. Tell them your problem. Ask if they can order 1/8" Baltic birch.
Postby greygoos » Mon Sep 25, 2017 10:47 am
I have used FRP which is about 35.00 a sheet at HD and Lowes. It bends easy takes adhesive, it is waterproof, etc. I used it on 2 trailers. After it was applied I covered it in aluminum, that was the finish I was going for
greygoos
Postby mallymal » Sun Oct 01, 2017 4:52 pm
What about aluminium composite, like they use for signage (brand names in the uk include a Dibond).
It's as thin as very thin ply, already has an aluminium skin, and will never rot.
Probably harder to bend round, but could be worth a think!
(But take no notice of me... I e been lurking for about 10 years and still haven't got round to building anything! :oops: )
mallymal
Images: 18
Postby mboardman » Sun Oct 01, 2017 5:14 pm
What you're describing sounds exactly like what Im using for the walls and roof now in my last two teardrops, but it simply wont take the bend in the hatch. Plus, its extremely heavy for the hatch. So Im hunting for other stuff...
-- Kansas City
mboardman
Images: 5
Postby kielyjw » Wed Nov 15, 2017 4:33 am
I know Home Depot used to carry bumpy fiberglass panels in 4 X 8 sheets. It is the same material used inside commercial freezers. It bends easily and glues well also. It sounds like what greygoos was talking about.
kielyjw
Postby bobwhite215 » Sat Dec 16, 2017 12:32 pm
mallymal wrote:What about aluminium composite, like they use for signage (brand names in the uk include a Dibond).
That is exactly what I am using. My exterior walls, roof and galley hatch are all lined with ACM. In fact, my roof is going to be a repurposed sign.
Sent from my XT1585 using Tapatalk
bobwhite215
Postby slowcowboy » Fri Dec 22, 2017 7:56 am
I used 1 by 6s butted end for end side by side for the roof and the hatch. then I first tried frp but the fiber glassed based plastic was to brittle and busted trying to fit around my tighter than normal curves on my first teardrop. I then moved to nrp full plastic base. and covered the hole teardrop in it. 5 to 7 years later no issues with nrp. . its bathroom shower stall stuff. not as durbable and tough as frp though. stratches easy the nrp. if your curves are not to tight or a benroy or a square weekender. you can easy glue on frp and cover with aluniom trim. issue with frp is nails are tough to go though it have to drill small holes. but yea they even use frp on the newer semi bull racks roofs on brand new cattle pots to cut down on weight. so it will take a cows head jammed into it. maybe not a cow horn. but its tough sh**. and its doest sctatch like nrp full plastic does. I fully plan to never use quarter inch plywood in any tears I build roofs or hatches. its how I easly beat the hatch spring back on my first teardrop. :D
slowcowboy
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
