frederick wall to floor
Postby martymcfly » Mon Feb 12, 2018 4:39 pm
What glue do you guys use on this joint? PL or TB? Also, I see where Tony does a pocket hole looking screw from the top, any problem with running screws up from the bottom?
martymcfly
Re: frederick wall to floor
Postby tony.latham » Mon Feb 12, 2018 4:52 pm
martymcfly wrote:What glue do you guys use on this joint? PL or TB? Also, I see where Tony does a pocket hole looking screw from the top, any problem with running screws up from the bottom?
You caught me munching on peanuts.
I screw from below after I've done the pocket holes. And I use PL Premium. It's got much better gap strength and a longer working time.
Postby martymcfly » Mon Feb 12, 2018 5:02 pm
TY.
martymcfly
