Anyone see any holes in my thinking?
ae6black wrote:I just bolted plastic "deck boards" sold at Lowe's to the bottom of my frame. Nothing fancy, but it works. I probably could have just used 2x4 treated on the bottom but I tend to overbuild. Instead of airplane, I built a tank because of the bending pressures that I thought I'd encounter every time I winched the thing off my trailer. I believe now, I could have just used a foam sandwich with just as much success. to each their own, my unit has served me well over the years and I continue to use it.
Art
ae6black wrote:I just used a couple of plastic impregnated deck boards that I bought from Lowes. I ended up making a square around the parimeter and then put one down the center for good measure. between the plastic boards and the the base treated 2x 4s that I put my plywood floor of the TD on I hollowed out a space to attach some 1/4 thick metal that I bolted in the sandwich that made up my TD foundation for the floor. The Metal with holes drilled in them stick out enough to attach a false chain link that I can hook a come along to. Not very inventive, but I take this thing off all the time and set the td on a series of 3 or 4 frames that I made out of 2 X 4s and 2x6s. A couple of long runners attached to the top of my frames that stick several feet out the back give me a place to winch the thing off. Don't really know if it helps or not but I generally put the TD wheels up on a board to let gravity assist me when I winch it off. Nothing fancy, it works, the top stringers on my frames stand proud and inch or so to help guide the TD from moving from side to side as I winch it off. Sorry, I never took any pictures. I just winch the thing off when I need the trailer. What takes me the longest time is unfastening the bolts that I put through the TD floor and foundation slides that hold it to the trailer. Half an hour or less once everything is unattached. Living in some one else's house and already having a travel trailer and the utility trailer that my TD sits on are trailers enough for me to worry about finding space for.
Art
this is why mine is being built as an enclosed with windows. Because I'll be hauling my mountain bikes in it for trips. Since the "bed" is nothing more than some form of matress on the floor it stays as a utility trailer.KTM_Guy wrote:I talked to my insurance guy about doing this, more for getting a life time utility plate over having to buy RV plates yearly.
He said not a good idea. First the law is clear in AZ if you can sleep in it (bed) it's a RV. Needs RV plates. Chances of getting pulled over for it are probably slim. But if you do you'll probably end up with a ticket and court date. Then you need to sell it to a judge that you are hauling a camper in your utility trailer.
The other thing was with the insurance company if you had a claim.
He said just know if you do it there could be a lot on headaches down the road.
Just something to think about.
Todd
Tigris99 wrote:this is why mine is being built as an enclosed with windows. Because I'll be hauling my mountain bikes in it for trips. Since the "bed" is nothing more than some form of matress on the floor it stays as a utility trailer.KTM_Guy wrote:I talked to my insurance guy about doing this, more for getting a life time utility plate over having to buy RV plates yearly.
Todd
Sent from my SM-G950U using Tapatalk
funny thing is that technically an officer can be reprimanded for issuing such a ticket as it's technically illegal. If your vehicle meets your home states laws, states you visit can stop you but if you prove on site that you are in compliance with your home state laws, legally they are required to let you leave without a ticket.LostCajun wrote:Tigris99 wrote:this is why mine is being built as an enclosed with windows. Because I'll be hauling my mountain bikes in it for trips. Since the "bed" is nothing more than some form of matress on the floor it stays as a utility trailer.KTM_Guy wrote:I talked to my insurance guy about doing this, more for getting a life time utility plate over having to buy RV plates yearly.
Todd
Different states different stuff....
In TN, less than a certain length, no matter what used for...even my boat trailer....only thing a trailer needs is air in the tires and working lights, no title, no registration, no nuthin....crazy stuff....even my 6x12 box trailer.....not needed....but, I have mine as it does make it easier to sell to someone who is out of state....TN has us print off a page from their website with the state law, to carry on out of state trips.....paraphrasing.....this won't stop an out of state cop from giving you a ticket for no lic plate.....but, you win in court.
