Wellcraft290 wrote:So I am new here and plan on building a squaretop camper. Looking for advice and any suggestions
I plan on building a frame.
5x12 2x3 .120 steel frame outside and 2x2 x.120 in the middle every two feet.
flexiride axle
then I will build the main shell out of 1x1 steel. inside 1/8th wood and on the outside 1/2" wood. sandwiched between will be foam sheet insulation.
plan on buying doors and rear hatch from challanger doors.
out of the 12 feet starting from the back
just shy of 2 feet of galley
then 8 feet of living space
front 2 feet will story the diesel heater and electrical items(batteries etc)
I plan on poly the exterior then monstaline the whole thing. thinking alum trim on the outside for looks but hopefully the monstaliner will seal all the edges from water.
thoughts ? ideas? issues?
thank you
and how would you seal the seams with monstaliner?
tony.latham wrote:
Fiberglass the walls flat on the bench. It's not a big learning curve. Youtube it.
*And it's not cheap. You need two gallons.
Also on the cost. I bought more than one gallon of 5:1 epoxy at $125 a gallon.
Wellcraft290 wrote:ugh probably be just over 5' wide on roof. was planning on laying the plywood "sideways" so had two seams.
caulk, bondo wood fill, fiberglass then most likely monstaline the whole thing. but now if I am going to fiberglass maybe just gelcoat paint which should be a lot cheaper.
So I am new here and plan on building a squaretop camper. Looking for advice and any suggestions...
