why do people put 1/8" (or thicker) ply on the outside of their structural wall
Another question for you, Tony: What's the purpose of the pieces you're gluing (that are currently clamped)
I’ve built all of my projects with a router, bushings and a template.noseoil wrote:The "poor man's milling machine" is just a decent router. If you get a 1 hp plunge base model & a few bits, that's really all you need for machining everything on a teardrop. Since you already have the skills to set up & run a mill, just set the clock back a few years & think analog, that should work well enough for the one-off stuff you'll need to do on a build.
noseoil wrote:...just set the clock back a few years & think analog...
rjgimp wrote:noseoil wrote:...just set the clock back a few years & think analog...
Sometimes I think the world might turn a lot smoother if more of us thought that way a bit more often about a lot more things.
One last question on this topic: is there a benefit to using 1/8" ply over the roof insulation before skinning in aluminum? Given the spars and loading directions, it seems like you don't need the additional strength that you get from sandwiching the walls.
I wish I had access to a large CNC setup. Most of the fabrication I have done has been metal machining on a non-CNC mill, which, unfortunately, doesn't exactly match up to the task you're describing.
