Hello.... I'm starting to think about how the floor will be constructed which will be inner framed members sandwiched with outer layers of 1/8 inch ply.
My question is.... do the outer ply layers get stapled to the inner framework..... or is it sufficient to just use a liberal amount of titebond, stack a ton of weight on the ply surface/and use clamps around the perimeter...
and let it "cure"?
I don't mind stapling the bottom layer that will sit on the trailer frame (and not be seen), but the top layer that will be visible on the interior of the cabin, I'd rather not see staples....so is just gluing sufficient?
Thank you for the help.
John
