How to install Timbren Axles (steps not completed yet)
Posted: Wed Jun 16, 2021 9:31 am
I haven't really seen a great resource on here for how to install Timbren axles so I thought I'd spend a moment going through it.
Timbren axles are actually an "axle-less" setup that consists of a spindle attached to a suspension device. Each side of the Timbren axle is independent of the other. Unlike most axles they bolt onto your frame which makes them particularly interesting for building a teardrop. They come in various configurations such as 4" drop spindle, straight spindle, and 4" lift spindle. As it might sound, the 4" lift spindle has roughly 8" more height than the 4" drop. In real-world setup, a 4" drop spindle on a 3" tubing puts the floor of the trailer about 16.5" off the ground.
When you first order your kit off etrailer it usually arrives in 4 boxes.
Box1: The main suspension pieces that bolt on
Box2: The control arms / spindles
Box 3 & 4: The hubs
The first thing you should do is INSPECT THEM. I always inspect things immediately and because of this I found that one of the grease seals was significantly damaged and I had to request a new hub.
It should be noted that there are parts missing from EVERY Timbren install. The reason for this is because they cannot know the method you're going to use to install the axles. MANY options are available but typically this is one of the following 3 methods.
1. On frames that are about 6" wide such as a C channel frame with an extended width added it's possible to bolt horizontally and vertically directly to the frame.
2. You can create an angle bracket in order to drill the holes and bolt through it.
3. You can use a 2" steel square tube to act as a cross member. It goes through the suspension pieces on both sides and is bolted or welded on. The biggest benefit of using this method is that you do NOT have to do any vertical drilling or fabrication. It's simply bolting the suspension parts to the frame and then sliding the tube across before bolting it down. The manufacturer doesn't have a minimum tube gauge. It probably depends on the width of your trailer and the engineering forces. Anything up to 8' I think is probably okay with 11ga or 3/16".
Things you're going to need that don't come with the kit:
6 1/2" grade 8 bolts and nuts.
12 1/2" grade 8 washers -- I didn't see anything about whether they need to be lock washers or not. I used loctite on the threads and flat washers. I think that properly torqued the washers shouldn't come loose either way.
150 lbs + torque wrench. Technically you should have one that'll do 450 lbs also but I don't think that's necessary because the hub when torqued to 450 lbs on the castle nut can't spin. Backing it off 1 turn as is mentioned in the instructions means you've loosened it enough to turn. You CAN just tighten it down until it doesn't turn and then back off 1/8 turn at a time until it turns but nothing feels loose.
1/2" drill bit
A little bit of oil to act as cutting oil (cooking oil in a plastic cup works well)
Grease
(I'm going to save this now and begin adding the steps starting with measuring the frame which is seriously one of the most important parts)
Box 3 & 4: The hubs
1/2" drill bit
Grease
