and the wood shop boss really frowns on anything non-wood going thru the table saw.
mnswamp wrote:First apologies if this has been asked before, I looked but didn't find...
Is there any reason that using multiple layers of 1/4¨ Foamular instead of kerfing a slab of full thickness insulation won't work? obviously you can't make too tight a corner, but on a 2'+ radius it seems like it should do fine. What am I not thinking about here?
tony.latham wrote:and the wood shop boss really frowns on anything non-wood going thru the table saw.
That's damn funny.
KCStudly wrote:I ran into issues with water based and air cured adhesives not curing between larger areas of 3/4 thick foam. The foam is not permeable, so it either takes a very long time or never for the middle of a panel to cure. 1/4 thick might be more permeable?
John61CT wrote:Even "wood" can include very poisonous materials
but certainly metal dust should not be littered, any more than chemical foam.
So the boss tries hard to keep people from doing stupid stuff...
